Sat, Feb 8, 2:29 PM CST
Subject: Lights
Sheedee ( ) posted Tue, 04 December 2012 at 6:57 PM · edited Thu, 06 February 2025 at 10:42 AM
Hello;
What kind of lighting in Poser Pro 2012 can be used for all the Stonemason products which mostly comprise of outdoor scenes?...
some kind of GI system?...
I tried using one IDL light…but with very crappy looking results!...
http://www.daz3d.com/shop/village-courtyard
because after all...all these products are also supposed to work in Poser...but then again... how to light them up?...
thsnks for viewing
LaurieA ( ) posted Tue, 04 December 2012 at 7:05 PM
Get Bagginsbill's Envirosphere.
dnstuefloten ( ) posted Tue, 04 December 2012 at 7:16 PM
Lighting is a very personal thing. I really like Stonemason's work, and especially this courtyard, and used it once as background with just a single spotlight. (You can see it here.) But I like dark, shadowy stuff. Nighttime, not daylight...
Poser Pro 2014
My personal website: Novels, photos, video, sculptures and more
Evidence of a Lost City: An animated movie and novel, in progress
Hag: A novel and live-action movie
3doutlaw ( ) posted Tue, 04 December 2012 at 7:32 PM
Second, for BB Env Sphere, and here are some really nice skies I just found today!
(free for personal and commercial per creator)
http://www.wuala.com/Olson/Photos/Optikz_360_Skies/
Medzinatar ( ) posted Tue, 04 December 2012 at 7:50 PM
The "Village Courtyard" has a built-in skydome.
You should make it invisible otherwise it will interfere with using EnvSphere or other IDL devices you might be using.
hborre ( ) posted Tue, 04 December 2012 at 8:04 PM
Take a look at the material shaders, I can guarantee Diffuse_values are set to 1.  Lower that value to 0.85 for starters, then apply a skydome with BB's shader arrangement and IDL.  There maybe other sections which could use a quick fix within PP2012 enviroment.
primorge ( ) posted Tue, 04 December 2012 at 9:49 PM
In what circumstances would it be necessary to lower the diffuse values? I'm using Poser 8 with the environment sphere and IDL. Non-GC.
3doutlaw ( ) posted Tue, 04 December 2012 at 10:05 PM
I am curious as well...why lower diffuse to 0.85?  Is that on all materials, skin, characters, environments, etc...?
JoePublic ( ) posted Tue, 04 December 2012 at 10:24 PM · edited Tue, 04 December 2012 at 10:30 PM
Single infinite + IDL and Envirosphere
Medzinatar ( ) posted Tue, 04 December 2012 at 10:34 PM
This is set OP referenced, Village Courtyard.
Single Infinite + IDL + BagginsBill EnvSphere w/ HDR image
JoePublic ( ) posted Tue, 04 December 2012 at 10:57 PM
Single Infinite for shadows/highlights and a white IBL for fill.
JoePublic ( ) posted Tue, 04 December 2012 at 11:04 PM
 And here a "proper" IDL render.
hborre ( ) posted Wed, 05 December 2012 at 12:53 PM
Your diffuse value determines how much diffuse light is reflected from your surface.  Nothing in nature reflects light diffusely at 100% with very few exceptions; specific wavelengths are absorbed and the remainder reflected back into the environment.  Darker material will reflect less than lighter.  Hence, setting a diffuse_value of 1 signifies that the texture surface is reflecting 100% of your environmental light, this does not occur naturally.  In addition, the render engine will misinterpret these values and attempt to calculate for a brighter surface.  Diffuse_values should be turned down for all surfaces, including skin textures and especially if you use it on the Poser Surface.
3doutlaw ( ) posted Wed, 05 December 2012 at 1:37 PM
Thanks for the explanation, I will give it a shot on the render I am working on.
vilters ( ) posted Wed, 05 December 2012 at 1:47 PM · edited Wed, 05 December 2012 at 1:49 PM
When incoming light is at 100%.
Outgoing light can never be more then 100%.
Unless, the object adds light like a candle, or a TV or PC screen would.
Diffuse + Specular + Reflection can never be more then 100%
In Poser :
Diffuse_Value + Specular_Value + Reflection_Value can never be more then 1.
0.95 would even be better for a total maximum.
Some light is absorbed by the object surface.
3doutlaw ( ) posted Wed, 05 December 2012 at 3:31 PM
Slowly but surely I am learning while all of those "tweaks" are, on the front page of Snarlygribbly's SceneFixer.  It seems it's not just coincidence after all...  :tongue1:
