DAZ|Studio F.A.Q (Last Updated: 2025 Feb 03 7:47 am)
Forgot to include another morph. It is called Pubic area Gape. This widens the area between the cheeks.
Well done man!
May I ask, Is this specifically designed for one particular shape (Character)? Eg. Victoria 5, Genesis Female or Stephanie 4 etc. By the looks of things I'm assuming that's V5 Base shape in your previews.
The genesis fixes I've came across are usually specifically made for one character. So I'm curious as to how it works with the other shapes if it is a 'one-shape specific'.
Mainly V5. It works on other shapes as well. Certain morphs are not required on other shapes but some are. Either way it still improves the other shapes bending appearance in some degree. Eg some shapes do not require the bendfix cause the genital area is flush and not sitting deep, but they will need some cheek adjustment.
Are you going to continue to include other bending areas like shoulders hint hint to round out this fabulous set or just the hip and genital areas?
---Wolff On The Prowl---
Well to be honest I just planned on this area because I was approached a while back from some guys who did "naughty renders" and they asked for a solution to have the genital area more exposed on Genesis and the rear to bend more realistic without that valley in between the cheeks. They kept complaining that you can't see anything and that it looks un-natural on the default shapes. That deal fell through so I was sitting with a few unfinished bending morphs that I just kept for personal use. What got me started on this again is that a thread regarding the same topic came up so I just decided to finish it and release it. I have no intention at this stage to create any more bending morphs for other body parts. This was a once off thing. But you never know. There are a few areas on Genesis that I am still unhappy with so I might tackle them at some stage. My plate is full at the moment but lets see what the future holds:)
There is actually a product by CJ studio that fixes that on Genesis. http://www.renderosity.com/mod/bcs/ideal-beauty-legs-for-genesis/94487
Just make sure you set the strength to 0.088 when using it on V5. It really is a fantastic product and I have no intention of making something similar. It does the job:) Don't know about how it works on longer legs. I will have to test it out.
Quote - Thanks Z! Appreciate your fast reply!
LOL I'm more on here than what I am at Daz..Plus all my notifications from this site work:)
I have that, actually. It looks just a little odd on V5Supermodel with the leg to one side and bent (for e.g., in ballet poses) and it can't handle Stephanie 5 + Model Body at all. I think it pretty much works on plain V5 or others that minimally change the thigh/knee proportions.
Perhaps it's just a limitation of the medium, or I need to do my own long legs bend fixer and release it as a freebie.
Quote - V5 1.0 +V5 Supermodel 1.0 or Stephanie 5 1.0 + Stephanie 5 Model Body 1.0.
Will do some testing when I get back from the long weekend. Have to drive soon. I'll try and reply via phone but I don't know if there will be signal.
LOL Derail all you like. It's what makes my threads fun lol. Wolfie and Spyro know all about it:)
fans self ME, derail a thread? No, not me..
So did you hear the one about the hot mama and the fur ball in the hay stack.... ? :lol:
It has to do with not finding the "Needle in the haystack" and "Hairballs" :lol:
From my understanding about the TOS is that the credit card companies and even PayPal have DAZ over a barrel about nudity of any kind. I'm sure they have their own conservative views too considering they live and operate in Mormon country.
A complete fix set? Shoo.. That will take a while. The only problem is that the fix might work on one shape and not on another. To create fixes to cater for all shapes is going to be a near impossible task. Not to forget that some people mix and match shapes. To test your fix on every possible variation is not really possible, and I guarentee that there will be a combination where the fix simply will not work. So the only solution is to make a fix set for V5, and a seperate set for M5 etc. It's a lot of work. What bending issues are you not happy with?
For me shoulders have been the bane of my existance. Why DAZ, at this point in the game, can't get their heads out of their asses about hero stances, diving, flying and all that involve the arms fully UP (where the thumbs touch each other sorta closeness). The shoulders look horrid as do the lats. I've attempted to make fix morphs but still havn't tried slaving the morphs to the Bruno morphs I made in order to keep things looking good when the arms are raised up. Arms up needs the limits turned off anyways since they are locked at a position that doesnt' allow for the pose I described above. Why, I have no idea. For me a set of upper body morphs and ones that are already set up and slaved to the DAZ supplied Arms Up & Arms Down slider would be awesome. Looked around for the examples but I must have trashed them on one of my cleanup days a while back.
Quote - A complete fix set? Shoo.. That will take a while. The only problem is that the fix might work on one shape and not on another. To create fixes to cater for all shapes is going to be a near impossible task. Not to forget that some people mix and match shapes. To test your fix on every possible variation is not really possible, and I guarentee that there will be a combination where the fix simply will not work. So the only solution is to make a fix set for V5, and a seperate set for M5 etc. It's a lot of work. What bending issues are you not happy with?
Fixes for V5 & M5 are enough.
and G5 if launched.
create a V5 as real as possible.
what if daz go for better weightmapping or real muscle solution in studio?
will solve all our problems.
I will look into shoulders in the week. But I will try and make time to see what solution can be made. Just extremely busy at the moment.
Thats it. 8 morphs in total. Combine them any way you want. If I think of any more morphs I will release them as freebies, but this set will be required. It is up for review as we speak.:)
I have to say that I admire your talent,and these bends look good,I probably will not get these since I don't do nudes .......but I do need to point out something .......your morph is makeing the genitalia look better BUTT it is also makeing it more obvious that she is missing another part ......ain't no spicturn ,which wasn't as obvious without your morph .........and to me it looks odd missing that little blind eye .... sorry.
Quote - Here is another example of what most vendors do to textures in that section. They just burn/darken the living daylights out of it.
Man I hate that also. looks even worse when using an unbiased renderer like Lux.
Your fixes look great, looking forward to trying them out.
Regards, Michael
Thanks dude. Yep, whenever I see that on a texture set it goes straight into photoshop:)
I made a little video showing it in action for anybody who is interested.
Okay that makes sense to me ......and I have to admit I had to go check both Gen4 figures and Gen5, made'em bend over and touch their toes ...... and then had a giggle fest,thinking about explaining this to somebody who doesn't deal with DAZ or Poser .....had another out right laugh attack .
Your morphs do look great though Zev0.
Thank you. Funny enough I had a couple of real people do the same as reference when I started this project. Made them touch their toes lol.
For those interested this will be at renderotica as well. Just became a vendor there:) There are some products I wish to sell in future that are not suitable for this store or Daz. Will let you know when this is available. Some of the promo pics had to be changed again in order for it to be released here. Nothing offensive, just some of them broke some rules, like a frontal shot of the genital area, even if clothed, which is not allowed:( At least I know extensively the do's and don't of Promo pics now lol.
Ok it is live at Renderotica for those who can't wait for the release here. Won't be long, it is busy pending...
My Renderosity Store
