Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 22 10:18 pm)
You wouldn't be able to apply the new UV's to the Poser Bear OBJ, you would get "incompatible facet structure".
Have to assume OP is using proper OBJ file. I have the freebie in question but it works fine for me.
The only thing I can think is maybe the blBear.rsr file was not deleted and is interfering. But I'm not sure if modern versions of Poser even look at that anymore.
I wonder if the OBJs might be similar enough that they weren't incompatible. Like, if the DAZ bear and the Poser bear are modifications of the same mesh.
This reminds me of the problem people had with trying to use the old DAZ Carousel. It used the old Poser 4 horse, and new versions of the Poser horse were just different enough that they showed up missing parts.
Thank you all for your tips and answers. I have used the Zygote bear from Poser 5 and it must be the same as the DAZ bear. The obj file has the name blBear. I think this is right. But maybe there is something wrong during the program reading the file.
All other animals work fine. Only the bear make trouble.
EnglishBob I will try this with the Hirachy tab and will come back. Thank you!
Dotthy,
Private home page DuF-Net.de,
Artist home page Arts-3D.com
"My education started the day I left
school" Mark
Twain
Quote - I have used the Zygote bear from Poser 5 and it must be the same as the DAZ bear.
It's not. Zygote and DAZ used to be one company, and many early Poser models were made by them. So the meshes are related, but not the same. I'd guess that's your problem. You need the bear for sale at DAZ, not the one that comes free with Poser.
Also, there are different versions of the Poser animals. I can't remember when it changed - Poser 7, maybe? So maybe that's why Bob got a different result trying to use the Poser bear than you did?
englishbob@ I have looked the Hirarchy editor all parts are set to visible. This seems to be not the problem.
I have several bear models from several poser editions from Poser 3 until Poser 8 when I add the texture to the bear of Poser 8. It is good but I lost the morphs by Lyne. Because they need another obj file.
Thank you again, for help!!!!! Have made tricky render ;-)
Dotthy,
school" Mark
Twain
Thank you, kind of you!!!!!!!
Dotthy,
school" Mark
Twain
I downloaded the wonderful stuff of Lynes freebies and later I have read the instructions and made the procedere right so far.
But when I load the file in Poser 7 and also in Poser 8, I got a bear without legs and arms. This is courious because I cannot change the material of it. It seems that the legs and arms are cutted away.
Please have a look on the test render.
Hope you have an idea?
Thanks
DOtthy
Dotthy,
"My education started the day I left school" Mark Twain
