Sun, Feb 2, 7:21 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Feb 02 6:50 pm)
Subject: Transfer utility for gen actor ?
kimbersue ( ) posted Thu, 20 December 2012 at 11:11 AM · edited Sun, 02 February 2025 at 7:19 PM
Hi, I have never been able to get the genesis character transfer utility to work correctly and wanted to ask.  I want to post an example so I can get my question correct.
I have Jazlyn for Genesis Bundle http://www.daz3d.com/shop/people/toon/jazlyn-for-genesis-bundle and I made a shirt for her in marvelous designer and loaded it to Daz Jazlyn for Genesis and the shirt loads correctly but when I use the transfer utility the shirt no longer fits correctly.
I was wondering if you can make clothing for Jazlyn for Genesis or only for genesis base figure then add in morphs later for Jazlyn?
Imported shirt to Jazlyn
After Transfer Utility.
Thanks
Kimberly
3D Artist Network  by Imaginative 3D: Where the “i” in “imaginative” stands for the individual” 3D artists showing off their creative designs.
terrancew_hod ( ) posted Thu, 20 December 2012 at 12:01 PM · edited Thu, 20 December 2012 at 12:02 PM
All genesis clothing has to fit the base figure. You either have to make the clothing for Genesis and then make the fits for Jazzlyn or make it for Jazzlyn then choose the "Reverse target from source" in the transfer tool (I think that's what it's named) and select the jazzlyn morph from the drop down under the source figure. If you choose the latter, you'll have to clean up the mesh for the base figure.
kimbersue ( ) posted Thu, 20 December 2012 at 12:14 PM
Quote - All genesis clothing has to fit the base figure. You either have to make the clothing for Genesis and then make the fits for Jazzlyn or make it for Jazzlyn then choose the "Reverse target from source" in the transfer tool (I think that's what it's named) and select the jazzlyn morph from the drop down under the source figure. If you choose the latter, you'll have to clean up the mesh for the base figure.
Thanks, that worked, the shirt needs to fixed up some around the breast but it is close enough to see if it works good enough for me to take time to learn the daz stuff.
terrancew_hod ( ) posted Thu, 20 December 2012 at 7:34 PM
Also keep in mind that original mesh you made on jazzlynn can be used for her fit. Just use morph loader pro on the shirt and name the morph similar to the autogenerated morph (using "replace deltas" in one of the options), something like FBMJazzlyn (check the morphs in the shirt for the name) and i think that may replace the morph with your version.
Bejaymac ( ) posted Fri, 21 December 2012 at 6:06 PM · edited Fri, 21 December 2012 at 6:06 PM
Always built around the base shape & then once you've got that rigged and saved as a figure you can start to reshape your outfit to fit the different Genesis morphs, or you can just use the crap auto generated ones.
kimbersue ( ) posted Fri, 21 December 2012 at 8:38 PM
I am making the clothing in marvelous designer and need the figure such as Jazlyn and julie to work with in MD software. I have figure out how to get the clothing so work on those two figures thank to help I got here.
Male_M3dia ( ) posted Sat, 22 December 2012 at 6:23 AM · edited Sat, 22 December 2012 at 6:24 AM
Drape on default genesis, Jazzlyn and Julie (make sure the scale is at 100% for both when you export the other figures so you won't have scaling problems). Export all. Now you have the default genesis shape, and the two fits for those characters.
kimbersue ( ) posted Sat, 22 December 2012 at 12:18 PM
What are people saving daz clothing as now? Last time I did anything there was a big debate about Daz 4.5 new saving options.
