Markschum is correct. You will be given several options for installation, each taking into account under which Operating System the application will reside. For Vista, Win7 & Win8, the recommended option is to install the base program to the Programs Files folder but load the content to a share folder under Documents. That share folder will be created as needed. The DSON importer should be installed in relatively the same location, under Documents.
Hi
I install all my graphics software on a separate drive from Windows and I put the runtime in the Poser Folder where it's easy to find things.
I haven't had any problems, I've done this in Windows XP, 7 and now in Windows 8.
I just find it more convenient to have every thing in one loacation.
Poser is not dependent on Windows to any great extent, unlike a lot of software I found that poser will run if it is copied to a computer running either version of Windows without even being installed.
I ran Poser in Windows 8 from the copy installed in Windows 7 with no problems.
So I'd say you can install it anyplace you want.
The advantage of not installing it on the C: drive is that if you have to reinstall Windows it will still be up and running with all you stuff intact.
Mike
If you shoot a mime, do you need a silencer?
I have the Poser application installed directly under the root directory, in:
C:Poser Pro 2012
(Poser Pro 2012 is just P9 with some extra bells and whistles)
I have the content installed in My Documents, under:
My Documents!Poser Content
The "!" in "!Poser Content" causes the folder to be listed as the first one in My Documents, because "!" has precedence in the list of alpha-numeric characters.
I am using Poser since version 2 and never install it in root partition and never have problem even i import Poser files in DAZStudio pro 4,5, Vue infinite 11 or Carrara
Now i have Poser pro 2012 installed in E: and DSON file with genesis working ok .Some preferences files are saved for example in c: users folder but all the majority of the soft and data are in others partitions
I have older runtines in D: and E: and indicate to Poser where they are and have no problem when i load the pzz or figures or props or poses
I prefer to keep my root C as small as possible for more fast backup of it And now i have an SSD with not as space as my older C hd
You just have verify and set correctly your soft parameters correctly
I am also using Windows pro 64 bits
Happy Holidays,
I decided to get Poser 9. I found it at a real good price, so I treated
myself to a Christmas gift.
I have Windows7, 64bit. Where is the best place to install it? I haven't
received it, but am getting prepared. I have Poser 7 and Poser 8 installed
under Programs (x86)
The reason I am asking is that I have the DSON importer and I would like to
use it for Poser 9, but I was told not to install it under the programs directory.
Thanks
