Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 6:38 pm)
For what I'm doing importing a Poser figure into Blender and then scaling my prop meshes in proportion to that has worked best. Since I'm exporting several props, once I knew the scale settings it was a simple matter to repeat the process and export each one. They imported fine and all at the correct scale I wanted (which actually turned out to be about 140% roughly of standard figure size), then all I had to do was make sure the origin points were all correct, edit the pp2 file so the geometry was external and they're working fine.
Thanks again for the tips.
I'm working on creating a PP2 file for an imported obj prop. I have edited the PP2 file to point at the geometry externally in the Runtime/Geometries directory and that part works fine. However, when I add the prop now the scale is too large.
Is there a way to set the scale in the PP2 so that the prop is still 100% of standard figure size?
Or would I need to go back to the original OBJ file, scale it down in my modelling software, then re-export the OBJ file?
Is there some other solution?
Thanks in advance.
