Sat, Nov 9, 10:08 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 8:30 pm)
Subject: Imported Obj scale and PP2 files
Tarkhis ( ) posted Mon, 31 December 2012 at 10:34 PM · edited Thu, 19 September 2024 at 7:58 PM
I'm working on creating a PP2 file for an imported obj prop.   I have edited the PP2 file to point at the geometry externally in the Runtime/Geometries directory and that part works fine.  However, when I add the prop now the scale is too large.
Is there a way to set the scale in the PP2 so that the prop is still 100% of standard figure size?
Or would I need to go back to the original OBJ file, scale it down in my modelling software, then re-export the OBJ file?
Is there some other solution?
Thanks in advance.
markschum ( ) posted Mon, 31 December 2012 at 11:06 PM
scale in Poser , then export the obj. The prop should now load at 100% scale if you point it to the new geometry.
Tarkhis ( ) posted Mon, 31 December 2012 at 11:16 PM
Ah, wondered if that would work but hadn't tried it yet.  I was just experimenting with importing a standard Poser figure obj into my modelling software and using that to scale the prop accordingly.  That seems to work also.
Thanks for the info!
hborre ( ) posted Mon, 31 December 2012 at 11:41 PM
In comparison to other model programs, Poser object scale is rather small.  You would need to rescale before exporting from the 3rd party app or perform the procedure markschum suggested.
Tarkhis ( ) posted Tue, 01 January 2013 at 6:27 AM
For what I'm doing importing a Poser figure into Blender and then scaling my prop meshes in proportion to that has worked best.  Since I'm exporting several props, once I knew the scale settings it was a simple matter to repeat the process and export each one.  They imported fine and all at the correct scale I wanted (which actually turned out to be about 140% roughly of standard figure size), then all I had to do was make sure the origin points were all correct, edit the pp2 file so the geometry was external and they're working fine.
Thanks again for the tips.
