Sun, Feb 2, 5:10 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 4:55 pm)
Subject: V4 dentures
JPayne ( ) posted Thu, 03 January 2013 at 11:08 AM · edited Sun, 02 February 2025 at 5:03 PM
Has anyone created replacement teeth for V4? I don't mean to slam V4's teeth but they seem a bit small overall without a whole lot of options. I'm not looking for vampire teeth or anything odd like that. Just some variation would be nice.
hborre ( ) posted Thu, 03 January 2013 at 11:50 AM
Online Now!
Ironman13 has teeth morph and texture package in her BOOM series, I believe for the mouth.  Haven't tested it out thoroughly yet and I may need to tweak the enamel shaders for PP2012 but it looks promising.
JPayne ( ) posted Thu, 03 January 2013 at 12:11 PM
Quote - Ironman13 has teeth morph and texture package in her BOOM series, I believe for the mouth.  Haven't tested it out thoroughly yet and I may need to tweak the enamel shaders for PP2012 but it looks promising.
Thanks for the response :) That looks to be a texture/shader set. What I'm looking for is a replacement teeth/gums model.
WandW ( ) posted Thu, 03 January 2013 at 2:09 PM · edited Thu, 03 January 2013 at 2:10 PM
You could import these as props and parent them to V4's jaws and set the existing jaws invisible.  You would need to do your own textures/shaders...
http://www.sharecg.com/v/57443/View/5/3D-Model/Teeth
You could also export the jaws of a figure with better looking teeth and bring them back as props and use as above; that has the advantage of having textures already...
JPayne ( ) posted Thu, 03 January 2013 at 2:23 PM
Quote - You could import these as props and parent them to V4's jaws and set the existing jaws invisible.  You would need to do your own textures/shaders...
Thank you :) Some good suggestions there. I'm not worrying too much about the shaders as I am about the overall shape. Thanks again.
NanetteTredoux ( ) posted Thu, 03 January 2013 at 2:58 PM
Do the teeth morphs in the V4 Morphs++ package not provide enough variation for you? You can change the size, make them irregular and so on.
Poser 11 Pro, Windows 10
Mark@poser ( ) posted Thu, 03 January 2013 at 3:13 PM
Seems like I recall these looked to be better modelled than V4's teeth. They're on sale for $5
http://www.daz3d.com/millennium-teeth
Zev0 ( ) posted Thu, 03 January 2013 at 3:24 PM
Depending on the success of this Product, I might do a Version for V4/M4. No Promises, but it does all that the OP is asking for. http://www.daz3d.com/forums/viewthread/12185/
My Renderosity Store
JPayne ( ) posted Thu, 03 January 2013 at 3:36 PM
Yeah, I tried the adjustments offered in ++ but it wasn't quite enough for what I was looking for. Thanks for the reply :)
Some people have much larger central incisors compared with lateral incisors etc.. I guess what I was looking for was more individual adjustment.
I may have to build my own or at least elaborate on the morphs available. To me, teeth can add as much character to a face as any other feature can.
Quote - Do the teeth morphs in the V4 Morphs++ package not provide enough variation for you? You can change the size, make them irregular and so on.
JPayne ( ) posted Thu, 03 January 2013 at 3:56 PM
This looks promising.
Quote - Depending on the success of this Product, I might do a Version for V4/M4. No Promises, but it does all that the OP is asking for. http://www.daz3d.com/forums/viewthread/12185/
shvrdavid ( ) posted Thu, 03 January 2013 at 4:19 PM
You can also export the teeth from other characters, then use them with other characters. They are already UVd to use the first characters maps as well.
