Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Quote - Ironman13 has teeth morph and texture package in her BOOM series, I believe for the mouth. Haven't tested it out thoroughly yet and I may need to tweak the enamel shaders for PP2012 but it looks promising.
Thanks for the response :) That looks to be a texture/shader set. What I'm looking for is a replacement teeth/gums model.
You could import these as props and parent them to V4's jaws and set the existing jaws invisible. You would need to do your own textures/shaders...
http://www.sharecg.com/v/57443/View/5/3D-Model/Teeth
You could also export the jaws of a figure with better looking teeth and bring them back as props and use as above; that has the advantage of having textures already...
"Oh - the manual says that? I have never read the manual - this must be why."Quote - You could import these as props and parent them to V4's jaws and set the existing jaws invisible. You would need to do your own textures/shaders...
Thank you :) Some good suggestions there. I'm not worrying too much about the shaders as I am about the overall shape. Thanks again.
Do the teeth morphs in the V4 Morphs++ package not provide enough variation for you? You can change the size, make them irregular and so on.
Poser 11 Pro, Windows 10
Seems like I recall these looked to be better modelled than V4's teeth. They're on sale for $5
Depending on the success of this Product, I might do a Version for V4/M4. No Promises, but it does all that the OP is asking for. http://www.daz3d.com/forums/viewthread/12185/
Yeah, I tried the adjustments offered in ++ but it wasn't quite enough for what I was looking for. Thanks for the reply :)
Some people have much larger central incisors compared with lateral incisors etc.. I guess what I was looking for was more individual adjustment.
I may have to build my own or at least elaborate on the morphs available. To me, teeth can add as much character to a face as any other feature can.
Quote - Do the teeth morphs in the V4 Morphs++ package not provide enough variation for you? You can change the size, make them irregular and so on.
This looks promising.
Quote - Depending on the success of this Product, I might do a Version for V4/M4. No Promises, but it does all that the OP is asking for. http://www.daz3d.com/forums/viewthread/12185/
Has anyone created replacement teeth for V4? I don't mean to slam V4's teeth but they seem a bit small overall without a whole lot of options. I'm not looking for vampire teeth or anything odd like that. Just some variation would be nice.
