Sun, Feb 2, 5:01 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 4:55 pm)
Subject: V4 dentures
JPayne ( ) posted Thu, 03 January 2013 at 11:08 AM · edited Sun, 02 February 2025 at 4:55 PM
Has anyone created replacement teeth for V4? I don't mean to slam V4's teeth but they seem a bit small overall without a whole lot of options. I'm not looking for vampire teeth or anything odd like that. Just some variation would be nice.
hborre ( ) posted Thu, 03 January 2013 at 11:50 AM
Ironman13 has teeth morph and texture package in her BOOM series, I believe for the mouth.  Haven't tested it out thoroughly yet and I may need to tweak the enamel shaders for PP2012 but it looks promising.
JPayne ( ) posted Thu, 03 January 2013 at 12:11 PM
Quote - Ironman13 has teeth morph and texture package in her BOOM series, I believe for the mouth.  Haven't tested it out thoroughly yet and I may need to tweak the enamel shaders for PP2012 but it looks promising.
Thanks for the response :) That looks to be a texture/shader set. What I'm looking for is a replacement teeth/gums model.
WandW ( ) posted Thu, 03 January 2013 at 2:09 PM · edited Thu, 03 January 2013 at 2:10 PM
You could import these as props and parent them to V4's jaws and set the existing jaws invisible.  You would need to do your own textures/shaders...
http://www.sharecg.com/v/57443/View/5/3D-Model/Teeth
You could also export the jaws of a figure with better looking teeth and bring them back as props and use as above; that has the advantage of having textures already...
JPayne ( ) posted Thu, 03 January 2013 at 2:23 PM
Quote - You could import these as props and parent them to V4's jaws and set the existing jaws invisible.  You would need to do your own textures/shaders...
Thank you :) Some good suggestions there. I'm not worrying too much about the shaders as I am about the overall shape. Thanks again.
NanetteTredoux ( ) posted Thu, 03 January 2013 at 2:58 PM
Do the teeth morphs in the V4 Morphs++ package not provide enough variation for you? You can change the size, make them irregular and so on.
Poser 11 Pro, Windows 10
Mark@poser ( ) posted Thu, 03 January 2013 at 3:13 PM
Seems like I recall these looked to be better modelled than V4's teeth. They're on sale for $5
http://www.daz3d.com/millennium-teeth
Zev0 ( ) posted Thu, 03 January 2013 at 3:24 PM
Depending on the success of this Product, I might do a Version for V4/M4. No Promises, but it does all that the OP is asking for. http://www.daz3d.com/forums/viewthread/12185/
My Renderosity Store
JPayne ( ) posted Thu, 03 January 2013 at 3:36 PM
Yeah, I tried the adjustments offered in ++ but it wasn't quite enough for what I was looking for. Thanks for the reply :)
Some people have much larger central incisors compared with lateral incisors etc.. I guess what I was looking for was more individual adjustment.
I may have to build my own or at least elaborate on the morphs available. To me, teeth can add as much character to a face as any other feature can.
Quote - Do the teeth morphs in the V4 Morphs++ package not provide enough variation for you? You can change the size, make them irregular and so on.
JPayne ( ) posted Thu, 03 January 2013 at 3:56 PM
This looks promising.
Quote - Depending on the success of this Product, I might do a Version for V4/M4. No Promises, but it does all that the OP is asking for. http://www.daz3d.com/forums/viewthread/12185/
shvrdavid ( ) posted Thu, 03 January 2013 at 4:19 PM
You can also export the teeth from other characters, then use them with other characters. They are already UVd to use the first characters maps as well.
Some things are easy to explain, other things are not........ <- Store ->   <-Freebies->
