Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 8:53 pm)
Quote - Plug white color to the displacement map, value 0.04 inches.
Other solutions, a legging is really close to the body, use second skin ;)
That displacement trick is exactly the thing I need, specially for semi transparent leggings where the skin messes up the shader.
Thanks, -Starkdog
Seems I'm a little late :) sorry about that. The displacement trick is awesome, an excellent idea and solution.
otherwise it's a combination of mesh density, as previously mentioned and collision offset. Collision offset defines how far your mesh will get to your cloth. If the mesh is too low a density then you will need a higher figure, probably somewhere between .5 and 1, with a higher density you can go below .5.
If you are getting poke through at a collision offset at 1 then the mesh is too low.
That said :) the displacement trick is really awesome, I'd go with that :)
John.
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
Smoothing in Poser will increase the size of a figure at render time.
Subdividing will shrink !!!! an object !!!!
=> Result is poking.
If the poking is even, U can use a displacement map to overcome it.
It the poking is uneven or "hard", you will have to increase the size of the clothing object to fit over the figure at render time.
For dynamcs? Increase the collision depth @ offset.
oh I forgot to mention the Simulation settings option :)
Above Cloth Self COllision are 2 options that can help in this case, when I get it I try "Object Polygon against Cloth Polygon", the default is vertex to vertex.
John
I used the Medium bodysuit mesh. Cut the mesh as required, moved a few polys to shape better and did a single subdivision.
Total poly count 3024.
Did a simulation, used basic settiungs, but had colission at 0.5. Switched off head, hands and feet option.
No poke through.
Silo Pro 2.1 used.
Rendered in PP2012.
All the best.
LROG
Who honors those we love for the very life we live?, Who sends monsters to kill us?, and at the same time sings that we will never die., Who teaches us whats real?, and how to laugh at lies?, Who decides why we live and what we'll die to defend?, Who chains us?, and Who holds the key that can set us free... It's You!, You have all the weapons you need., Now Fight!
![file_490167.jpg](https://live.cdn.renderosity.com/forum/threads/2861791/file_490167.jpg)
I created some leggings for Anastasia, and currently, they are dynamic (will be conforming eventually). In running several cloth simulations, I still get pokethrough, regardless of collision settings. Do you have any suggestions?Thanks, -Starkdog
