Hello Magnolia
Try the following:
Goto Display,(on the top menu)
Go Down to Guides
Select Focus Distance Guide
A X will come visible on your screen.
In the Parameters palette select your camera=> Usually your main camera you are rendering with.
Turn the dial focus_Distance to get your X (you will see it going in and coming out when you turn the dial)
Turn that dial to get the object you want to focus on in focus. just like the old manual focus dial on an old camera.
Render.
If this does not help?
What was the MSR you where rendering with?
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
Ok, thanks for posting the render settings
All is good but???? You hear me coming??
Irr. Catching is rather high, set at 32 for starters
Indirect Light Quality is also on the hi side; reduce to 50
Pxel samples can be 3-4-5, take it to 10 but 29 is extremely hi
Min Shading Rate => There is your problem
For very clear and sharp pictures set it at 0.2
(and set Post filter size at 3 on sync, not on box)
For draft renders, but still OK, set MSR at 1
Fast and OK rendering?
Raytrace bounces at 1
Irr catching, set at 0 (yes zero)
Indirect Light quality set at 7
Pixel samples at 3
MSR at 1
Post filter size at 3 on Sync
Happy posering
Tony
Dev
"Do not drive
Quote - Ok, thanks for posting the render settings
Pxel samples can be 3-4-5, take it to 10 but 29 is extremely hiMin Shading Rate => There is your problem
(and set Post filter size at 3 on sync, not on box)For draft renders, but still OK, set MSR at 1
Pixel samples at 3
MSR at 1
Post filter size at 3 on SyncHappy posering
Tony
Thanks Tony , I am have always had trouble with Render Settings, I have never really understood them. I really need to find some tutorials for render setting.
Thank You for your help.Regards.
![file_491567.jpg](https://live.cdn.renderosity.com/forum/threads/2863480/file_491567.jpg)
I am trying to render a figure in PP2012. But when the render is finished the figure is blurry.I have no idea how to fix it. I am not sure if it is a setting in my render setting or something else.
I would really appreciate it if somone can help me
