Attached Link: http://www.youtube.com/watch?v=U5T6LNjH2nk
Part 3.Skeletons, attaching them, Clothes, UV savings, and reducing the object file.
I won't make a fuss usually, but you need to know this info.
Steve
Attached Link: http://www.youtube.com/watch?v=vZmIOlhhwpQ
Part 4.In this episode I show the reduced figure imported again into Carrara and we look at the quality of the model, the shading domains, and how to attach a skeleton.
Now we import an aniblock (that could easily come from a BVH file).
Next we look at some of the issues that will arise if you model for skeletons. Particularly the legs can be a problem.
Finally without UV maps you'll be limited to colours (not texture files) with your shaders. although you might get lucky I guess at a texture file would still look ok (box mapping).
However for far away shots these figures look fine as colours and contours only as I will show in a forthcoming tutorial.
Attached Link: http://www.youtube.com/watch?v=CFa6mBjvERY
Hi,I've now made 33 cyberpunks using this method, they all animate fine via BVH files (brought in via DAZ and aniblocks).
This is a 3 part series, starting at part 2 and ending at part 4 (part 1 was a demo)
I am releasing part 2 today, part 3 on monday, part 4 on tuesday. Then I'm doing a little scene with music, lights and everything to celebrate!
Rather than explain the process here, I'll leave you to click on the link.
Note these characters are not intended for close up or talking use.
