Mon, Sep 9, 1:42 PM CDT
Renderosity Forums / Animation
Welcome to the Animation Forum
Forum Moderators: Wolfenshire, Deenamic Forum Coordinators: Anim8dtoon
Animation F.A.Q (Last Updated: 2024 Sep 07 12:02 am)
In here we will dicuss everything that moves.
Characters, motion graphics, props, particles... everything that moves!
Enjoy , create and share :)
Remember to check the FAQ for useful information and resources.
Animation learning and resources:
[Animations]
Subject: In an animation, moving a whole frame, from within Python
Anthony Appleyard ( ) posted Tue, 12 February 2013 at 5:55 AM · edited Mon, 09 September 2024 at 12:15 PM
I want to make a length of animation run at half the speed. So I would do this:-
If the animation is n frames long, make it 2*n frames long.
for A in poser.Scene().Actors():
. for j = n (-1) 1 :-
. . for P =  each parameter dial in turn of actor A :-
. . . B = all the frame information (value, whether it is a keyframe, spline settings) for frame j of parameter dial P of actor A
. . . delete frame j of parameter dial P of actor A, if it is a keyframe
. . . delete frame 2*j of parameter dial P of actor A, if it is already a keyframe
. . . set frame 2*j of parameter dial P of actor A to the value and keyframe settings of B, if B is a keyframe
Please, has this been done before?
Anthony Appleyard ( ) posted Tue, 12 February 2013 at 6:58 AM
Most of it looks easy, but how could I pick up and set the spline settings?
poisinivy ( ) posted Sat, 16 February 2013 at 7:32 PM
I would render at 30fps save it in AVI and then in your movie editor you should be able to control the rendered scene speed in the movie eidtor  I use adobe premiere  and i can slow it own to 3 fps if i need to.  Just a short cut I use  for slow motion shots. :)
Anthony Appleyard ( ) posted Sun, 17 February 2013 at 12:58 AM
Thanks. But after I have done what I described in the first message in this thread, I may need to edit the result some more.
