Wed, Nov 27, 5:47 AM CST
Subject: For the Absinthe Minded
chris1972 ( ) posted Sun, 24 February 2013 at 6:18 AM · edited Wed, 27 November 2024 at 5:46 AM
Promo shot for new product. My render times were getting longer and longer, to an unacceptable level as I added more items to the scene. I happened to read something regarding the number of light emmitters and render times. When you import objs they come in with light emmitter checked as the default. I went through and unchecked light emmitter on all furnishings and etc items, leaving it on only on walls,ceilings, floors, neon signs and emmitter panels. It resulted in a huge reduction in render times. This is 1000x1200 ray trace bounces @ 6 all other settings to the max, this took 3.5 hrs to run
ghostman ( ) posted Sun, 24 February 2013 at 6:23 AM
I like it. Very nice.
"Dream like you'll live forever. Live like you'll die tomorrow."
Join PoserLounge Chat
Saxon3d ( ) posted Sun, 24 February 2013 at 6:52 AM
They say Absinthe makes the heart grow fonder. I found a store the other day that still sells Absinthe, and I would really like a glass of it from your bar.  looking great
hborre ( ) posted Sun, 24 February 2013 at 7:44 AM
Very impressive.  3.5 hours is not bad for a render with plenty of glass and reflections.
linnymac ( ) posted Sun, 24 February 2013 at 9:09 AM
Very nice indeed!
charlie43 ( ) posted Sun, 24 February 2013 at 11:09 AM
Been about 45 years since I had the pleasure of a dance with the Green Fairy. Thanks for the memories. Your work is most excellent.
C~
grichter ( ) posted Sun, 24 February 2013 at 11:25 AM
Looks stunning.
The boys and the girls are going to break out their roaring 20's or Victorian clothes and props and have a grand ol' time when this becomes available.
Gary
Eric Walters ( ) posted Sun, 24 February 2013 at 12:00 PM
That is a Poser render? DANG!
MistyLaraCarrara ( ) posted Sun, 24 February 2013 at 12:14 PM
thirstifying!
very beautiful
SamTherapy ( ) posted Sun, 24 February 2013 at 2:26 PM
That looks amazing.  Sadly, absinthe and I don't get on well at all.  After getting completely and thoroughly bladdered on it and suffering the mother of all hangovers the next day, I decided I'd rather drink gasoline.  :)
Superb looking product and render, though.
Miss Nancy ( ) posted Sun, 24 February 2013 at 2:36 PM · edited Sun, 24 February 2013 at 2:39 PM
chris, notice how refractive shader in current poser version(s) causes contact shadows at bases of glasses.  then look at wine glass on table cloth in room with indirect light.  one won't see that shadow.  check bagginsbill's posts on how to correct this.  he even has wine glass freebie, but I can't use it, as it has wine shader incorporated into the goblet section, rather than wine prop, which would use refractive shader.  ISTR anthanasius has also posted thin glass shader several times here.
Eric Walters ( ) posted Sun, 24 February 2013 at 9:40 PM
I noticed that too, BB has a fix? That is good to know!
Quote - chris, notice how refractive shader in current poser version(s) causes contact shadows at bases of glasses.  then look at wine glass on table cloth in room with indirect light.  one won't see that shadow.  check bagginsbill's posts on how to correct this.  he even has wine glass freebie, but I can't use it, as it has wine shader incorporated into the goblet section, rather than wine prop, which would use refractive shader.  ISTR anthanasius has also posted thin glass shader several times here.
AnAardvark ( ) posted Mon, 25 February 2013 at 1:30 PM
Absinthe is back! (BTW, my local wine shop stocks about six brands!)
BTW, the two correct uses of absinthe are as follows:
  1. Absinthe Drip. Put a lump of sugar (or a cube) on an absenth spoon, pour about one oz. of absinthe over it into a glass, then drip a couple of oz of ice water over the sugar until it disolves.
  2. In mixed drinks, but very sparingly. (In terms of drops, dashes, or rinsing the glass.) I'm particularly fond of it in a Corpse Reviver #4.
Miss Nancy ( ) posted Tue, 26 February 2013 at 3:39 PM
does absinthe knock one out like they say in old literature?
anyway, just tried rendering (~500X500) frilled lizard's freebie bottle of jack using thin glass shader.  it took 8 hrs., at same render settings that only require 10 - 15 min. to do  ~1400X800 render with multiple instances of thin glass shader on single surfaces.
hence with any luck, things may be better in next version.  also necessary to rethink thin glass shader IMVHO.
Miss Nancy ( ) posted Wed, 27 February 2013 at 8:44 PM
found that one of BB's shaders speeds this up quite a bit.  of course, one would consult with him prior to selling it.
AnAardvark ( ) posted Tue, 16 April 2013 at 2:42 PM
Quote - does absinthe knock one out like they say in old literature?.
Not unless you drink a lot of it. It's usually about 80 proof.
primorge ( ) posted Tue, 16 April 2013 at 4:17 PM · edited Tue, 16 April 2013 at 4:20 PM
Used to live with the master brewer of Obsello Absinthe (Spain) before he left the US. He's recently returned to the states and has set up a distillery in Salinas, CA (whisky). Anyway, before he left for Spain I used to drink quite a bit of his potables, never really developed a taste for la fée verte and prefer a good beer. You really don't want to go on a bender and throw absinthe in the mix. ;)
http://www.obsello.com/
http://www.linkedin.com/pub/bryan-alexander-davis/3/37b/209
DarkElegance ( ) posted Wed, 17 April 2013 at 7:48 PM
Quote - Promo shot for new product. My render times were getting longer and longer, to an unacceptable level as I added more items to the scene. I happened to read something regarding the number of light emmitters and render times. When you import objs they come in with light emmitter checked as the default. I went through and unchecked light emmitter on all furnishings and etc items, leaving it on only on walls,ceilings, floors, neon signs and emmitter panels. It resulted in a huge reduction in render times. This is 1000x1200 ray trace bounces @ 6 all other settings to the max, this took 3.5 hrs to run
o.0 is that poser??
https://www.darkelegance.co.uk/
Commission Closed till 2025
DarkElegance ( ) posted Wed, 17 April 2013 at 7:54 PM
any link for that post? or script etc?
Kendra ( ) posted Wed, 17 April 2013 at 11:02 PM
That's an awesome render.  I'd love to try absinthe sometime.  It can't be any worse than Korean Soju.  (never... ever... EVER... again)
...... Kendra
Paul Francis ( ) posted Thu, 18 April 2013 at 3:42 AM
Awesome render and I love the Mucha screen!
My self-build system - Vista 64 on a Kingston 240GB SSD, Asus P5Q Pro MB, Quad 6600 CPU, 8 Gb Geil Black Dragon Ram, CoolerMaster HAF932 full tower chassis, EVGA Geforce GTX 750Ti Superclocked 2 Gb, Coolermaster V8 CPU aircooler, Enermax 600W Modular PSU, 240Gb SSD, 2Tb HDD storage, 28" LCD monitor, and more red LEDs than a grown man really needs.....I built it in 2008 and can't afford a new one, yet.....!
My Software - Poser Pro 2012, Photoshop, Bryce 6 and Borderlands......"Catch a  r--i---d-----e-----!"
