Have you initialised the M4 morphs?
Go to RuntimeLibraries!DAZ folder.
Double click the DzCreateExPFiles-M4.bat file.
This will then initialise the morphs.
All the best.
LROG
Who honors those we love for the very life we live?, Who sends monsters to kill us?, and at the same time sings that we will never die., Who teaches us whats real?, and how to laugh at lies?, Who decides why we live and what we'll die to defend?, Who chains us?, and Who holds the key that can set us free... It's You!, You have all the weapons you need., Now Fight!
It was a long time ago but when I installed M4 I used the DS option to install to a separate runtime so it wasn't necessary to put in a dummy Poser.exe. It might be worth your while to try to install M4 again selecting the DS fiiles option, initialise it and then install the morphs ++ into the same runtime. When you inject the morphs the dials should appear on the parameter panel when you select M4.
I trust you are using Windows. If you are using a Mac you want to use the /Runtime/Libraries/!DAZ/DzCreateExPFiles-M4.command to initialise the figure.
I installed it as you did without any issues. Try searching on "mr477" in Runtime/Libraries/!DAZ/Michael 4/ There should be 185 results if the morphs are installed properly...
"Oh - the manual says that? I have never read the manual - this must be why."Well many thanks for your replies, most appreciated.
Unfortunately I still have the problem.
I tried running the update M4 file, same.
I found the Mr477 files, so this is OK
Some information
I am using Windows 7 ultimate
I am using Poser 2010 (86) also called PoserPro.
I use external runtimes
The exe file to launch this is poserpro.exe , hence since M4 base installation file looks for a poser.exe file then I wonder how this could ever have been installed in this version of Poser?
As said once I found this problem I found a way out was to make notepad poser.exe file.
So my installation is a bit non-standard.
I had a look for the injectdelta files ( these are cr2, right?), see figure 1, they are in M4base/runtime/libraries/charactor.
Since I feel the problem probably lies in the file setup I have took some snapshots of the complete installation. It seems I can only attach one file, so I attach the location of the injectdelta files.
Could you please review and give me your thoughts.
Whilst I usually have external runtimes I do not mind to put M4 into the Poser program runtime. I tried this again making a dummy poser.exe file and whilst it went it I cannot find it on the Poser library?
Since M4 is a major charactor in my series I need to solve this if possible.
Once item, if I try to apply the morphs there is a small movement of M4 right leg, so there is some communication.
Thanks for your help
Looking forward to any thoughts on how to solve this problem.
I can send some more file structure pics if necessard
Cr2 is short for Character; it's the actual base figure.
You don't want to install anything except python scripts and add-ons into the main Poser program runtime when using Windows 7.
I noticed your external runtime is called 'M4 base'; did you install Morphs ++ into the same Runtime? This is required for them to work properly...
edit; the default location for the M4 cr2 is Runtime/Libraries/Character/DAZ People/ how did they end up in Character?
"Oh - the manual says that? I have never read the manual - this must be why."I also noticed that your icon associations are all screwed up. The CR2's should be referring to the PoserPro icon, not IrfanView. As WandW posted, the morph pack should be installed into the exact runtime as the base model.
BTW, the correct and official name for your Poser Version is PoserPro. Everyone will know exactly how to better respond to queries if you use the appropriate version title.
Quote - I also noticed that your icon associations are all screwed up. The CR2's should be referring to the PoserPro icon, not IrfanView.
That may not be incorrect, as a .cr2 is also a Canon raw image file...
As an aside, the M4 cr2 has an earlier date than mine, meaning it's an earlier version; the current version is dated 11/20/2008...
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
hello
I am a amateur user of poser 2010 using external runtimes, so far no problems.
I tried to install M4 into the external runtime and had difficulty until I made a notepad file, poser.exe, and put it in on top of the runtime. M4 base file installed OK and I registered it.I then installed M4 morph ++ into the same runtime,no problem.
I can load M4 and move it around.
It responds to the set poses no problem.
It does not however respond to the set morphs, I did press the inject all morph buttons.
Any help or assistance appreciated.
Regards
