Fri, Nov 22, 3:57 PM CST
Subject: octane poser plugin demo
pruiz ( ) posted Wed, 27 February 2013 at 4:20 PM · edited Fri, 22 November 2024 at 3:42 PM
I follow the unzip instruction and get this error "
An errror occurred importing addon OctaneRender for Poser :
ERROR: [Error 3] The system cannot find the path specified: u'C:Program FilesSmith MicroPoser Pro 2012RuntimePythonaddonsOctaneRender for Poser64 Demo'
What am I doing wrong. Of course the octane render option does not appear in the render column of poser.
Amigo968 ( ) posted Wed, 27 February 2013 at 6:01 PM
Sorry, can you help me. Where can I get this Betaversion?
Thank you for your help.
pruiz ( ) posted Wed, 27 February 2013 at 6:33 PM
http://render.otoy.com/downloads.php
Amigo968 ( ) posted Thu, 28 February 2013 at 2:02 AM
Thank you for the link.
rokket ( ) posted Thu, 28 February 2013 at 4:36 AM
Quote - I follow the unzip instruction and get this error " An errror occurred importing addon OctaneRender for Poser :
I guess the obvious would be to check the specified path. Make sure that the plugin is in the folder it's looking for.
It might be under the folder X86 instead of the normal program files folder. It won't work there.
bblogoss ( ) posted Sat, 02 March 2013 at 3:32 PM
Some UAC problem I guess. Make sure you're running as an administator account when unzipping the files.
GKDantas ( ) posted Sat, 02 March 2013 at 4:00 PM
I have the sam eproblem, when I tried to run Poser a second time everything works fine and its amazing to see how fast it is.
Follow me at euQfiz Digital
face_off ( ) posted Wed, 06 March 2013 at 5:51 AM
I had never seen this error, then had about 5 reports within a day or two.  It is actually caused by the plugin using the Poser Temp folder to store everything.  Unfortunately the Poser Temp folder can gets wiped at any time (and when it does, you get the above error).  So the latest release (not demo yet, sorry) uses the Poser Preferences folder to keep the important stuff instead of the Temp folder.  Sorry for the troubles you had :-
Paul
Creator of PoserPhysics
Creator of OctaneRender for Poser
Blog
Facebook
GKDantas ( ) posted Wed, 06 March 2013 at 8:01 AM
Hi Paul, just want to undertand why the final version needs both the standalone and the plugin to work?
face_off ( ) posted Wed, 06 March 2013 at 3:08 PM
From a licensing point of view, the plugins and the renderer are treated as different products.  So they are purchased separately (or as a bundle).  This is actually a good way for it to be handled, since a substanital number of users are running multiple plugins.  The DazStudio plugin will be out soon and I see many users having both Poser and DS plugins.
Paul
Blog
Facebook
