Wed, Jan 8, 12:04 AM CST
Subject: How to put all the Poser controls back in the right place
strongbear ( ) posted Fri, 08 March 2013 at 10:36 AM · edited Tue, 07 January 2025 at 11:56 PM
Ok this might seem a really basic question and I'm almost embarrassed to ask, considering I've been using Poser for well over 10 years now. However, for some reason some of the various palettes and controls went out of sync and all of the controls disappeared. When i clicked launch to factory state it still stayed that way.
I then went to the Window menu and clicked on the various pallettes (parameter dials, light controls etc) and had them docked rather than floating. When it came to the animation controls and UI memory dots, I'm having difficulty getting them to be positioned exactly where I want them.
The first picture is how it should be in its default state with the animation controls and UI dots not overlapping the document display or the library controls. They sit nicely below the document window and never go beyond where I've marked it with red Xs.
The second picture however is what has currently happened when I've lost the controls and then clicked on them again in the Window menu. I've managed to position everything else correctly, but as you can see the animation controls stretch all the way across the bottom, overlapping part of the document display and library. When i've tried to put the UI dots in as well, that also overlaps the document display and library. When I've tried to reposition it, that's how it has ended up over there to the right of the animation controls.
Does anyone know how to get it back to what it should be? I just can't seem to place those two controls on the bottom correctly.
Thanks
hborre ( ) posted Fri, 08 March 2013 at 10:41 AM
Go to General Preferences and reset to Factory default.  That will place everything back to where they belong.
strongbear ( ) posted Fri, 08 March 2013 at 10:43 AM
That's what I did already. I mentioned that in the first paragraph. However, it didn't change it back to what it should be.
I've also tried resizing those controls and it doesn't help either.
geep ( ) posted Fri, 08 March 2013 at 11:12 AM
Reinstall ???
cheers,
dr geep ... :o]
edited 10/5/2019
millighost ( ) posted Fri, 08 March 2013 at 11:38 AM
before reinstalling try to find the ui-preference file in your application data folder. On my system it is named
"C:/users/millighost/Application Data/Poser/8.0/English/Poser UI Prefs_1280x1024.xml"
Name differs slightly depending on poser version and screen resolution. Remove that file and restart.
heddheld ( ) posted Fri, 08 March 2013 at 11:47 AM
there is (I think) a preferances file you can delete in the poser folder (runtimeprefsenglish) but thats in P7 so not sure its same in 2012!!!!! DO NOT delete until someone else agrees with me 'cos I can an have got proggys mixed up in the past
ps its just a txt file so could be an edit or two will fix it! hopefully this info will get you on the right track
stewer ( ) posted Fri, 08 March 2013 at 12:30 PM
There are two places in the Poser prefs where you can reset to factory state, one in the Document tab and one in the Interface tab. You did try the one in the Interface tab and not the Document tab, I hope?
LaurieA ( ) posted Sat, 09 March 2013 at 11:15 AM
Quote - Reinstall ???
Gawd no! Just get rid of the preferences file. LOL
geep ( ) posted Sat, 09 March 2013 at 11:27 AM
Quote - > Quote - Reinstall ???
Gawd YES .... but only when absolutely neccesary. :lol:
cheers,
dr geep ... :o]
edited 10/5/2019
MistyLaraCarrara ( ) posted Sat, 09 March 2013 at 6:56 PM
the animation palette would need to be in the center column with document window.
you managed to start a bottom row, under all the columns.
it's a tricky business to drag the lil palettes just so.
if you drag everything out of the bottom row, the row space should disappear.
MikeMoss ( ) posted Sat, 09 March 2013 at 10:44 PM
Hi
If you don't want to delete the preferences file just change the name of it by adding Orig to the start of it.
If it causes problems just change the name back.
Mike
If you shoot a mime, do you need a silencer?
FLIM7777 ( ) posted Sat, 24 September 2022 at 7:28 AM
i cant find my animation palette
Richard60 ( ) posted Sat, 24 September 2022 at 12:01 PM
C:\\Users\\YOURNAME\\AppData\\Roaming\\Poser\\12 is where the UI layout file is located.  If you cannot get the animation palette to show by clicking its name located under the Windows tab at the top of Poser, then most likely you have it floating in the space of a disconnected monitor.  Either A: hook up a second (third) monitor to see if it shows up there OR B: open a explorer window to the location listed above (your Poser directory may be Poser Pro and a different version #) ad find the file that starts "Poser UI Prefs_" the last part of that file will be the screen resolution of the monitor you are using, this might be 1920x1080 or something else. Also be aware that you can have multiple Prefs files, you get one for each monitor that you run Poser on.  With the Prefs file that matches your current monitor (with Poser Closed) rename that file to something else I put a X in front of the name.  Run Poser and it will create a new default Prefs file.
RobZhena ( ) posted Tue, 04 October 2022 at 3:03 PM
When you fix it, I recommend creating a UI dot in each room for the layout you like. That has saved me many a time when I have accidentally messed up the palettes.
A_Sunbeam ( ) posted Wed, 05 October 2022 at 3:33 AM
RobZhena posted at 3:03 PM Tue, 4 October 2022 - #4445838
Same here! Excellent suggestion.
hornet3d ( ) posted Tue, 18 July 2023 at 4:21 AM
Online Now!
judyswoope posted at 2:56 AM Tue, 18 July 2023 - #4470469
I never create a UI dot before. Can you guide me?
Once you have the layout as wanted all you need do is click on one of the UI tabs and the setup is remembered.  I have two set at the moment the top left corner returns the setup to my preview preferences irrespective of how the layout is at that point.  The next tab does the same for when I am in the Materials room.
