Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 02 2:40 am)
There's the Toddler from Daz and Baby 4 on ShareCG.com. Both require Kids 4 and morphs. Baby 4 can be scaled up to look older since it starts from the K4 base.
________________________________
Quote - The K4 toddler, when released, only worked with DAZStudio and not worked correctly with that Poser version at the time. However, if you have P9/PP2012, the scaling problem has been corrected and the feature now usable.
Interesting. I didn't buy it when it first came out because it was DS or Carrara only. It still says that in the description. But the box on the bottom lists Poser as compatible software. I wasn't sure if it was with DSON or what.
Quote - The scaling issue with the toddler's arms is easily fixed by selecting the shoulders (left and right) and rescaling the Scale (xyz) slider to 86% (top number). Dani
Absolutely, and if you use the 'show dials' python script you can further refine scaling with individual x, y or z scalers for the shoulders and collars.
Actually I was having a problem with the back of the toddlers head. It still appears to be there in 2012. There is a ridge where the neck joins the head. It's kinda scary looking. Don't have a picture though. Have you turned the baby around?
Quote - No problem here. Just rendered an image and the baby's head is fine in the back.
Must just be me. I'll try reinstalling over a fresh K4 or maybe I should apply Morphs++ before the Toddler. BTW, where'd you get the hair, is it part of the texture?
What would be the best figure to use for a Poser two-year-old boy? I think the Matt figure looks slightly older (about 5 or more) and the next one down from that is the Millennium baby who is obviously too young.
Are there any other kids around, or are there any morphs for Matt to make him look younger still?
