Poser Pro 2012 has a separate content runtime it should be in your user documents folder put the parts there
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
You can't put content in the main program folder (such as Program Files/SmithMicro/PoserPro....etcc). There is a content folder under Users/"YourComputerName"/MyDocuments/PoserPro2012 Content (if you have Windows 7). Other versions of Windows should have something comparable. If you're on a Mac I don't have a clue...lol. You should put your content there OR Create a separate runtime anywhere you like and as long as it has the proper folder structure, you can link to it from within Poser.
If you are new to Poser, it might be easier if you just go to the Content tab, select "Install from Zip archive" wait for the pop up and then navigate to the Anastasia file,(whereever it is stored on your computer) click Open and then click Install to upload and then after you get the message that says "File operations done" (usually within a few seconds) look in your library under downloads. If your installed content library is not visible, you will need to add it to the list of libraries.
It may not be the preferred method of many, but it works fine for me.
"People who attempt define what art is or is not, are not artists"---Luminescence
I apologize for my delayed response, and sincerely appreciate the great community here for their responses.
I feel like a fool for not noticing the "install from zip" option earlier. Using that method worked for me. Previously I had installed the files in my "program files/smith micro/poser pro 2012/runtime" directory, which did not work.
For future reference for anyone else who stumbles upon this thread, I'm running Windows 8 Pro (64 bit). It's actually on a Microsoft Surface Pro.
Thanks again for all those who responded with the very helpful information.
Yup! It's a Surface Pro. Which is capable of running legacy (Windows 7 desktop software) http://www.microsoft.com/Surface/en-US/surface-with-windows-8-pro/home
Admittedly a bit expensive for a tablet, but you pay for performance, right? :)
So let us know if it actually runs or just crawls
Charles Péguy
I've been running it without any problems. Navigating, manipulating and such works well. I'd say the worst problem is some of the buttons/controls can be difficult to tap, but when using the stylus that came with it the tablet, it's not really an issue.
Rendering takes time, of course, but I don't have much of a comparison for how long renders typically take in Poser, as I'm new to it. But, after installing Anastasia, and rendering one of the setups that is included with it (model, pose, lights, backdrop), it renders in probably ~2 minutes.
The tablet hasn't had problems with much of anything I've thrown at it. I've loaded Mass Effect 2, Bulletstorm, and a couple other games, and it runs them well. Typically at 720p, with around medium settings. Obviously not a gaming PC, but it definitely holds it's own.
If you'd like to know anything else, I'd be happy to help, as you've all been helpful to me.
First off, welcome! :)
Quote - ... It's actually on a Microsoft Surface Pro.
A tablet is not an effective tool for creating 3D art.
Bottom line, you're going to quickly find the Surface woefully inadequate for your needs as a burgeoning artist.
Quote - Rendering takes time, of course, but I don't have much of a comparison for how long renders typically take in Poser, as I'm new to it. But, after installing Anastasia, and rendering one of the setups that is included with it (model, pose, lights, backdrop), it renders in probably ~2 minutes.
That render time will increase sharply when working with more complex scenes.
Quote - The tablet hasn't had problems with much of anything I've thrown at it. I've loaded Mass Effect 2, Bulletstorm, and a couple other games, and it runs them well.
Video games use visual effects that are baked in to the software. There's no raw processing power required to render them.
Thank you for the tips! I don't plan on using the Surface as my primary machine. It's a toy, but a fairly capable one, and thought I'd share my experience, since others seemed interested. :)
I have a desktop machine both at home and work that are more than capable machines. As well as a fairly capable laptop. While I don't have the experience with Poser, I do have experience with other 3d modeling software. 3ds max and zbrush are part of my stable of software. Though rendering can be a chore in 3ds max as well.
Again, just sharing my experience with the Surface Pro. It wouldn't be the choice of an artist, I'm sure, but I'm still impressed with what it can do. After effects, premiere and photoshop as well. Though stylus pressure sensitivity in Photoshop isn't currently working (Adobe has mentioned an update to resolve the problem).
I am starting over with Poser. I bought the Poser 12 Pro. Its installed, but I am just now getting content. I backed off of Poser 9 the first time because of how difficult it was for me to understand the file structure and the Runtime libraries.
Well, now I have my first zip file so you can see how my search brought me here. I think the option to install from zip may be the only way for me to go.
I don't want to screw this one up. I have lots of old Poser 9 and Daz content spread around my computer and my USB hard drive.
I intially started setting up my files a couple of years ago, following one of the tutorials here, I even bought a couple of books but found there is more than one way to approach Poser files and I think I ended up with a hybrid system.
So, now I have this zip file sitting on my external hard drive in a folder cascade F: > My Poser Files > Downloaded Zip Files. I also have a files structure that I created from the tutorial that remains on my C drive at C:Poser Content, which has children folders of >Accessories, Clothing_Female, Clothing_male, Figures_Hair, FIgures_People, and Renders. Each of these folders contains a Runtime Folder.
When I installed Win8, I moved everything that I could find related to Poser or Daz to this F:My Poser Files but beyond that, all I have done is try not to trash my stuff.
What's the best way to start a salvage?
Quote - I am starting over with Poser. I bought the Poser 12 Pro. Its installed, but I am just now getting content. I backed off of Poser 9 the first time because of how difficult it was for me to understand the file structure and the Runtime libraries.
I have a tutorial I wrote for someone else:
The Young Person's Guide to Runtime Organization
Shoot me your email & ship it right out to you.
Hello,
I am new to poser, and after reading a few articles and seeing some videos, I was convinced to purchase Anastasia.
After following the installation instructions (copying the "Runtime" folder to the poser install directory). I fire up Poser, load the Alyson 2 model, and go to the "Poses". However, I don't see the Blackhearted folder. I tried searching, but still nothing.
Am I missing something? Any assistance would be appreciated.
Thanks!
