Mon, Jan 20, 1:11 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: Giving my PP-2012 lightsets away....
JoePublic ( ) posted Sun, 31 March 2013 at 10:25 AM · edited Mon, 20 January 2025 at 1:09 PM
file_493181.txt
I guess the easiest way to help those having trouble lighting their scenes in PP-2012 would simply be to share the lights I'm using.
So attached is a zip (remove .txt from the file and unzip, then place in your lights folder) containing four lightsets I pretty much use for everything.
For those with a low end GC (Or those who simply prefer the non-hardware shader preview look), there are two lightsets called GOOD PREVIEW:
These contain EIGHT preview lights which DO NOT render and ONE or TWO lights which do.
Those PREVIEW LIGHTS are simply there to create a nice OpenGL preview IF HARDWARE SHADING IS DISABLED in your PREVIEW SETTINGS.
The IDL light contains only ONE SUN and NEEDS IDL AND AN ENVIRONMENT to properly work.
The NON-IDL light contains an additional white IBL for ambient and should NOT BE USED with IDL.
The NO PREVIEW lights are meant for those with high end graphic cards who use FULL HARDWARE SHADING for their OpenGL preview.
They DO NOT contain preview lights, just the render lights. (But these are OpenGL enabled, so you can still see what you're doing)
They come as IDL (Only one sun) and NON-IDL (Sun + white IBL).
Only the SUN light gives shadows on all four sets.
Shadows are by default NOT BLURRED. You can easily set this up yourself.    I recommend 1.4 to 2.0.
I use these lights for almost anything, but if you work in a tight, completely enclosed space, you need to replace the SUN with a similar point light that is located closer to your scene, as walls will block the default sun.
ALL LIGHTS NEED GAMMA CORRECTION ENABLED !
While these lights work very well for most "daylight" renders, you can and should of course modify them any way you like.
Tint the sun, dim it down, add additional lights, etc.
JoePublic ( ) posted Sun, 31 March 2013 at 10:27 AM
And here are my render settings for fast "good enough to post in a thread" renders.
JoePublic ( ) posted Sun, 31 March 2013 at 10:28 AM
 And here my high end settings:
JoePublic ( ) posted Sun, 31 March 2013 at 10:31 AM
You'll notice that my IDL settings are very low, which is perfectly fine as long as you don't use IDL AS YOUR ONLY LIGHTSOURCE.
If you just use IDL emitters and no "proper" Poser light, you need to drastically raise the IDL settings to prevent artifacts.
Which of course will dramatically raise your render times.
nobodyinparticular ( ) posted Sun, 31 March 2013 at 12:03 PM
Thank you. This is incredibly generous. And thank you for the usage tips.
Alisa ( ) posted Sun, 31 March 2013 at 3:53 PM
Thanks so much!
Cheers,
Alisa
RETIRED HiveWire 3D QAV Director
hborre ( ) posted Sun, 31 March 2013 at 5:26 PM
Thank you so much.  Looking forward to trying these out.
booksbydavid ( ) posted Mon, 01 April 2013 at 11:26 AM
Error: Page Not Found.
foxylady1 ( ) posted Mon, 01 April 2013 at 2:43 PM
Thank you very much, this was very generous.  The usage tips are great.
foxylady1 ( ) posted Mon, 01 April 2013 at 2:58 PM
Joe,
I am still trying to download this, but I keep getting a "page not found" or it just times out.  Should I keep trying, or is there something wrong?
JoePublic ( ) posted Mon, 01 April 2013 at 3:14 PM · edited Mon, 01 April 2013 at 3:28 PM
Attached Link: http://rapidshare.com/files/777260084/Giveaway%20Lights.zip
Seems attachements suddenly don't work ???
Anyway, here's a Rapidshare link:
JoePublic ( ) posted Mon, 01 April 2013 at 3:24 PM · edited Mon, 01 April 2013 at 3:28 PM
Also remember that WardrobeWizzard can dim, brighten or tint multiple lights  if you open the WW Python window and then select: "Utilities" --> "Lights".
JoePublic ( ) posted Mon, 01 April 2013 at 3:42 PM · edited Mon, 01 April 2013 at 3:46 PM
And here is how V4 using her default textures and EZSkin 2 looks with my GOOD PREVIEW-NO IDL lights.
(The leftover blue diffuse color tint was removed by using SnarlyGribbly's SceneFixer script)
On the left is the OpenGL preview WITHOUT HARDWARE SHADING and on the right is the rendered version using my FAST settings but SSS enabled.
(If you use hardware shading the preview will of course look different, while the rendered pic should look the same)
If your monitor setings are a lot different than mine, simply use WardrobeWizzard as explained above to brighten or dim the lights until you're happy with them.
foxylady1 ( ) posted Mon, 01 April 2013 at 3:55 PM
Got it, finally.  Thank you.
Why did Renderosity stop .txt file downloads?
JoePublic ( ) posted Mon, 01 April 2013 at 4:09 PM · edited Mon, 01 April 2013 at 4:09 PM
Glad it worked.
Rendo is quite slow for me ATM. Maybe they are working on the servers ?
Anyway, here again V4 default with EZSkin. FAST render settings + EZSkin.
Again the GOOD PREVIEW-NO IDL light set, but I converted the SUN from INFINITE into a POINT light that I could move inside the building.
Strenght = 100, Shadow = 1.0, Blur = 1,4, Attenuation = constant.
The "white" IBL stayed the same. No other lights.
JoePublic ( ) posted Mon, 01 April 2013 at 4:14 PM
Oh, and all lights are parented to the MAIN CAMERA so your scene and figures will stay well-lit wherever you point your camera.
PilotHigh ( ) posted Mon, 01 April 2013 at 7:07 PM
Thank you very much!
momodot ( ) posted Tue, 02 April 2013 at 10:16 PM
Super nice! Thank you.
booksbydavid ( ) posted Tue, 02 April 2013 at 10:44 PM
Finally got them. Thanks, Joe.
pitklad ( ) posted Wed, 03 April 2013 at 1:58 AM
Thank you very much Joe!
My FreeStuff
JoePublic ( ) posted Thu, 04 April 2013 at 10:46 AM
Glad you like them.
BTW, if, for whatever totally unthinkable reason, you really, really, really don't want to use Gamma Correction, switch the intensity of the SUN light from 80% to 50%, and the white IBL filler light from 11% to 30%.
And of course disable GC in your render settings.
As you can see the result will look very close to the GC lights without IDL.
But remember, for SSS and IDL to work correctly, you also need GC.
momodot ( ) posted Thu, 04 April 2013 at 11:16 AM
It is a personal taste thing but as an oil painter I like the shading (shadow) on the higher IBL render shown on our right.
Madrigal ( ) posted Thu, 04 April 2013 at 1:04 PM
Thank you very much for these! :)
911-69.blogspot.co.uk/
AetherDream ( ) posted Fri, 05 April 2013 at 10:04 PM
Thank you so much.
"People who attempt define what art is or is not, are not artists"---Luminescence
nobodyinparticular ( ) posted Sat, 06 April 2013 at 12:57 PM
These lights make even my crappy work look good. Thank you once again.
aldebaran40 ( ) posted Sat, 13 April 2013 at 1:43 PM
Thank you very much Joe for share this set
Michaelab ( ) posted Sat, 13 April 2013 at 5:15 PM
Not for Poser 9 I take it?
JoePublic ( ) posted Sat, 13 April 2013 at 5:44 PM · edited Sat, 13 April 2013 at 5:45 PM
"Not for Poser 9 I take it?"
Well, they were made to work with PP-2012' Gamma Correction, but if you adjust the values of the "Sun" and the "IBL-Filler" light to "Gamma-Off" like explained above, they probably work in Poser-9, too.
