Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
The site was up for a while but it's down again. You can get V4-WM and Outfitter at RDNA; http://www.runtimedna.com/Poser-Place/
"Oh - the manual says that? I have never read the manual - this must be why."If you convert then to conforming figures they work after a fashion. The problem is that the V4WM pelvic floor moves upwards and forward when the legs are bent, which doesn't happen in a real human because of the pubic bone. It should be possible to rework the maps in that area so it works more realistically.
On a side note, props in general can somewhat problematic with a weightmapped figure because the mesh can move independently of the bone, but the prop is parented to the bone...
"Oh - the manual says that? I have never read the manual - this must be why."Poser only supports one weightmap per joint, so it is incompatible with Daz "tri-axial" weightmapped figures, but DS supports both traditional and their tri-axial weight maps, so I believe that it is only the tri-axial weighting that is incompatible between the two.
Certainly, V4-WM poses in DS and when exported via Collada has all of her weight maps, so DS is keeping the "poser" weight maps.
Probably more appropriate for the Freebie Forum at this point...
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
You can get V4 weight mapped over at Runtime DNA for free. Plus the outfitter to adjust her clothing.
