Thu, Jan 9, 3:29 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 09 2:14 am)
Subject: V4-WM is Here!
nobodyinparticular ( ) posted Fri, 05 April 2013 at 1:55 PM
You can get V4 weight mapped over at Runtime DNA for free. Plus the outfitter to adjust her clothing.
75oroboy ( ) posted Fri, 05 April 2013 at 2:31 PM
Thanks for the heads up NIP, think I'll go and check it out. Thanks for the info.
DarkElegance ( ) posted Fri, 05 April 2013 at 7:53 PM
Quote - Thanks for the heads up NIP, think I'll go and check it out. Thanks for the info.
it is so worth it. its really nice.
https://www.darkelegance.co.uk/
Commission Closed till 2025
Connatic ( ) posted Mon, 06 May 2013 at 6:47 PM
A product that really needs to be in the marketplace is an elbow-bone JCM fixer.  V4WM is great except for the horrid blunt elbows.  I have tried combinations of several "fixer" morphs and scripts.  Nothing works, at least for me.
bopperthijs ( ) posted Tue, 07 May 2013 at 4:59 PM
file_494255.txt
I've made two elbowfixes (left and right) for V4-WM in Zbrush. Here are the injectionposes. They are jointcontrolled, they are not perfect but perhaps you can use them.
Best regards,
Bopper.
Connatic ( ) posted Tue, 07 May 2013 at 5:15 PM
@bopperthijs -  Wow, thank you very much!
Rose2000 ( ) posted Fri, 24 May 2013 at 5:19 PM
Quote - I've deleted a number of posts about the site being downsince it's up again. Not mad at anyone... but they are just noise in a very long thread.
So Poser Place is up again?? Thats so odd!!!
Oh well..
WandW ( ) posted Sat, 25 May 2013 at 4:23 PM · edited Sat, 25 May 2013 at 4:25 PM
The site was up for a while but it's down again.  You can get V4-WM and Outfitter at RDNA; http://www.runtimedna.com/Poser-Place/
Rose2000 ( ) posted Sat, 25 May 2013 at 6:38 PM
moogal ( ) posted Wed, 12 June 2013 at 6:36 PM
Quote - But if the figure is not in one part can you not just weld it in the group editor?
Yeah, only vertices within a certain distance get welded together.  You can import the object into Wings though, select the unwelded seams, and "connect" will create new edges/polys which bridge the gap.
morphious ( ) posted Mon, 08 July 2013 at 12:38 PM
It sucks that yiou can't use any of the previous gental props with this. :(  They don't align anymore.
WandW ( ) posted Mon, 08 July 2013 at 12:56 PM · edited Mon, 08 July 2013 at 12:58 PM
If you convert then to conforming figures they work after a fashion.  The problem is that the V4WM pelvic floor moves upwards and forward when the legs are bent, which doesn't happen in a real human because of the pubic bone.  It should be possible to rework the maps in that area so it works more realistically.
On a side note, props in general can somewhat problematic with a weightmapped figure because the mesh can move independently of the bone, but the prop is parented to the bone...
Parthius ( ) posted Sun, 14 July 2013 at 4:11 PM
When I import V4-WM into DS, I get the following message many times: Warning: "Vertex index for weight map out of range on line xxxxxx". Does anyone know what the issue is?
nobodyinparticular ( ) posted Sun, 14 July 2013 at 5:26 PM
Daz and Poser use incompatibe weight mapping systems.
Parthius ( ) posted Sun, 14 July 2013 at 8:27 PM
Poser only supports one weightmap per joint, so it is incompatible with Daz "tri-axial" weightmapped figures, but DS supports both traditional and their tri-axial weight maps, so I believe that it is only the tri-axial weighting that is incompatible between the two.
Certainly, V4-WM poses in DS and when exported via Collada has all of her weight maps, so DS is keeping the "poser" weight maps.
basicwiz ( ) posted Fri, 09 August 2013 at 3:07 PM
Are there any objections to my "unstickying" this thread? I think it has pretty well served its purpose.
kobaltkween ( ) posted Fri, 09 August 2013 at 11:09 PM
I think that depends on your perspective.  I've had people ask me what V4 WM is when I credit it.
WandW ( ) posted Sat, 10 August 2013 at 8:48 AM
Probably more appropriate for the Freebie Forum at this point...
