Tue, Jan 14, 10:36 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 11 12:30 am)
Subject: Reality Render thread. A new beginning.
Pret-a-3D ( ) posted Thu, 11 April 2013 at 12:15 AM
Quote - Wow, Reality 3 is an eye opener. I was thinking that coming from Reality 2 much of it would be second nature, but after a couple of days I see I was wrong. I miss the sliders for values and trying to understand the different skin setting values is a nightmare, similar to trying to see what the different SSS nodes did in poser.
Most of it is automatic, you don't need to tweak the SSS at all, in most cases. Of course you can change the mat toGlossy and you will be back into Reality 2 land.
Quote - I am so used to not setting an exact render dimension in poser and just going with the preview size, but now I have to since Reality tells me to, bummer.
This is the same than Reality 2, you must use a camera with a set resolution. It's also easy to fix in Poser:
  • Create a new scene
  • Set the size that you want to be by default, for example 1280x720
  • Call the preferences and set "launch to preferred state"
  • Click on "Set Preferred Scene"
From that point on you don't have to set the size of the scene.
Quote - I also can't get copy and paste to work, probably a setting that is confusing me. I don't usually look at documentation, kind of a hands on person, but I guess it's time to visit the RUG.
This should be just as usual, what is not working for you?
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+: https://plus.google.com/106625816153304163119
The Reality Gallery: https://reality-plug-in.deviantart.com
Pret-a-3D ( ) posted Thu, 11 April 2013 at 12:16 AM
Quote - I'm planning to get the cross grade for Poser.  Can't use it, but its cheap, and Paolo needs the money.  :-)
I appreciate the support but I hope that you will get some use from it.
Cheers.
Paolo
Tw: @preta3d
UHF ( ) posted Thu, 11 April 2013 at 12:40 AM
Quote - I appreciate the support but I hope that you will get some use from it. Cheers.
Rayman29 ( ) posted Thu, 11 April 2013 at 1:34 PM · edited Thu, 11 April 2013 at 1:46 PM
I'm pleased to see implementation of the volume parameter  in R3.
For me, the lack of it in R2 for DAZ is my biggest problem.
It adds depth that was sorely lacking.
callad ( ) posted Thu, 11 April 2013 at 4:14 PM
Attached Link: Full size: "Dress me in Colors"
'Dress me in Colors' was made with one MeshSpot, one CurvedLight and one Gel-Cam from my Reality Light System freebie.
Needless to say it's a R2 render..
Dress me in Colors
Pret-a-3D ( ) posted Thu, 11 April 2013 at 6:31 PM
Quote - I'm pleased to see implementation of the volume parameter  in R3.
Thanks. Here is a video that shows it in action:
http://www.youtube.com/watch?v=CcT6XS5C4bY
Paolo
Tw: @preta3d
Rayman29 ( ) posted Thu, 11 April 2013 at 8:04 PM
Great.
I was thinking of moving to Poser and R3.
That said, I haven't used Poser for at least ten years. And I do like the Genesis features of Studio 4.  So I'll probably wait for the Studio version of R3.
FSMCDesigns ( ) posted Fri, 12 April 2013 at 11:51 AM
Quote - 'Dress me in Colors' was made with one MeshSpot, one CurvedLight and one Gel-Cam from my Reality Light System freebie.
Dress me in Colors
Stunning image!!
Regards, Michael
My DeviantArt page
bobvan ( ) posted Fri, 12 April 2013 at 2:02 PM
Very nice Charley R3 is looking promising some folks are producing better renders in a day or then I did in a month or so... Perhaps cause they have more experience overall they tweak maps ect still something to look forward to.. I finally get my machine back on Monday..
RFreise ( ) posted Fri, 12 April 2013 at 5:37 PM
Online Now!
Love the image Charley
Reggie68 ( ) posted Sat, 13 April 2013 at 2:42 PM
Just trying out some pose and hand presets for some of the range of guns from motokamishii. This one is the BRM92 (Beretta M92).
Gemma is using the Weaver Stance (ish).
sparklesss ( ) posted Sun, 14 April 2013 at 1:18 AM
Hi Callad
I am having problems with the Gel Cam, everything else works beautifully however when I add the Gell cam add the gell, change the material to light in Luxus and enable it. But it still just shows as white light.
What am I doing wrong? I know I must be missing a step but I can’t work out what.
Thanks.
callad ( ) posted Sun, 14 April 2013 at 3:37 AM
Quote - Hi Callad
Thanks.
Hi Sparkless, please keep in mind that my set was designed for use with Reality, not Luxus. In Reality it works without having to adjust anything.
I think you make a mistake by turning the Gelmask itself into a light. You should turn the 'RealityLight GEL 1 (2) or (3)' into a light which is a very tiny light. It is so tiny you almost won't see it in your viewport.
For the Projectors you should turn the 'RealityLight Mini 1 (2) or (3)' into a light.
If it still does not work you can always ask the creator of Luxus to help you out on this one. http://www.daz3d.com/forums/viewthread/18543/P1275
Hope this helps.
sparklesss ( ) posted Sun, 14 April 2013 at 10:58 AM
Thanks  Callad from your reply it looks like I was switching on the right light, and everything else including the projector works really well, so I have asked on the Daz forum and hopefully will get a reply there. So far your light set is amazing, and I have had fun playing with it.
Thank you.
I created this picture with the projector from your set.
sparklesss ( ) posted Sun, 14 April 2013 at 11:50 AM
For those here who are trying to learn Luxus, HeraldOfFire told me that with the gells, you need to turn the light on, and then go to each gell and turn it into glass, then change the transmission colour to match the the gell.
It then works fine, phew.
bobvan ( ) posted Sun, 14 April 2013 at 11:53 AM · edited Sun, 14 April 2013 at 11:54 AM
Most of us are waiting for R3 and forgoing Luxus...
callad ( ) posted Sun, 14 April 2013 at 12:24 PM
A wonderful image Sparkless!
I read you have gotten your answer about the Gel-Cam too. I did not mention setting the GEL mask to glass, for Reality automatically recognizes the mask as being made of glass. :)
UHF ( ) posted Sun, 14 April 2013 at 6:16 PM
Quote - Most of us are waiting for R3 and forgoing Luxus...
So its not just me?
bobvan ( ) posted Sun, 14 April 2013 at 6:28 PM · edited Sun, 14 April 2013 at 6:29 PM
Quote - > Quote - Most of us are waiting for R3 and forgoing Luxus...
So its not just me?
No I am sure Luxus is a decent product (I am passed this vs that) I am just used to the way Reality works & it's simplicity. I know Luxus has more options at this point, I am just not interested in having to figure out that I need to manually type formulas to accomplish what I want to do. R3 will allow all those same options without having to worry about all of that..
Pret-a-3D ( ) posted Sun, 14 April 2013 at 6:30 PM · edited Sun, 14 April 2013 at 6:30 PM
Quote - R3 will allow all those same options without having to worry about all of that..
And more! ;)
Thank you for your support, much appreciated.
Paolo
Tw: @preta3d
bobvan ( ) posted Sun, 14 April 2013 at 6:32 PM · edited Sun, 14 April 2013 at 6:35 PM
Quote - > Quote - R3 will allow all those same options without having to worry about all of that..
And more! ;)
I see some nice stuff with the poser users but there seems to be issues also, but knowing you and your exellent CS issues will be resolved. Its like any new softare that gets put out..
It's looking like I am going to be operational again round Wens have 2 commish projects waiting I hope all will run smoothly with Win 8. Sounds like it will...
sparklesss ( ) posted Sun, 14 April 2013 at 10:19 PM
For me the issue was purely price, for a while my budget has been severely limited and hobbies have had to take second place. So at $10 I could afford to take a chance and see if I liked it.
From what I have seen reality is a great program as well, once I would have bought both and seen which one I found the easiest, now price tends to dictate what I can and cant buy.
Pret-a-3D ( ) posted Mon, 15 April 2013 at 12:10 AM
Hi Bob.
The Poser environment is a lot different and there are many variables in there. Because of the node-base materials it is a lot harder to provide conversions of materials than the Studio system.
Also, Reality 3 provides support for almost all the Lux procedural textures, something that is not present in Reality 2. This situation provides the conditions for more complications.
When the first version of Reality was released we had a similar development. A lot is also caused by inexperience. The posts in the forum today, almost a a week after the release, are very positive and in fact we see the first renders.
There is another update that we are testing right now and that will go our probably next week, after the testers verify that everything is in order.
That update fixes a few crucial issues and speeds up the export substantially.
Cheers.
Paolo
Tw: @preta3d
bobvan ( ) posted Mon, 15 April 2013 at 12:15 AM · edited Mon, 15 April 2013 at 12:16 AM
Quote - Hi Bob.
Cheers.
I was saying that you will resolve the issues I was actually being positive about the support you offer which is why I am waiting or R3 rather then learn another plug in...
I have no interest / need in poser... By what experienced artists like Mike are saying Studio seems easier to use...
Pret-a-3D ( ) posted Mon, 15 April 2013 at 12:32 AM
Absolutely, Bob, I wasn't arguing at all :)
I was just taking the opportunity to give a little more BG about what's happening in the Poser camp. Not trying to convert you :)
Cheers.
Paolo
Tw: @preta3d
bobvan ( ) posted Mon, 15 April 2013 at 12:35 AM
Quote - Absolutely, Bob, I wasn't arguing at all :)
Cheers.
Ok sorry for missunderstanding...
klown ( ) posted Mon, 15 April 2013 at 9:04 AM
forgetting whats-its-name and patiently waiting for R3 for DS4
and by patiently I mean impatiently. :)
FSMCDesigns ( ) posted Mon, 15 April 2013 at 9:22 AM
Quote - The Poser environment is a lot different and there are many variables in there. Because of the node-base materials it is a lot harder to provide conversions of materials than the Studio system.
You can say that again, LOL. For the years I used poser the node aspect of the material room is the one thing that never made any sense to me. Pretty sad considering i mastered the cloth room. The slight instances of the node system in the Reality UI are throwing me off a bit, but hopefully I will figure it out. I expected to be cranking out a few renders to support the product for the poser users to see by now, but due to being lost with the new UI and the clumbsyness of Poser after having gotten use to DS, I have yet to produce any
Regards, Michael
My DeviantArt page
Pret-a-3D ( ) posted Mon, 15 April 2013 at 9:31 AM
Mike, I will be making videos that show how to use the new Reality Material Editor. Once you get the logic of it, which is rather simple, you will see how easy is to work with it.
I think that it's much simpler than using nodes.
Cheers.
Paolo
Tw: @preta3d
FSMCDesigns ( ) posted Mon, 15 April 2013 at 9:31 AM
Quote - I have no interest / need in poser... By what experienced artists like Mike are saying Studio seems easier to use...
Not harder, just different than DS and the Reality UI is different than what we are used to with DS. I would not suggest getting it just to play with Reality as there is a learning curve like any software. I still have poser 7 installed as it was my fav version and most stable. I hate the library palette in Poser 2012. for me it is slow to load and now that i have been spending more time with it, I find it freezes sometimes to where I have to save the scene and then restart poser, what a pain. I feel those that are die hard poser users have never used DS, since that is how I was
Regards, Michael
My DeviantArt page
FSMCDesigns ( ) posted Mon, 15 April 2013 at 9:33 AM
Quote - Mike, I will be making videos that show how to use the new Reality Material Editor. Once you get the logic of it, which is rather simple, you will see how easy is to work with it.
Cheers.
Thanks Paolo, looking forward to it.
Regards, Michael
My DeviantArt page
Pret-a-3D ( ) posted Mon, 15 April 2013 at 9:39 AM
Mike, you might take a look at the ShaderWorks Library Manager, it might suit you better than Poser's built-in library.
Cheers.
Paolo
Tw: @preta3d
FSMCDesigns ( ) posted Mon, 15 April 2013 at 9:59 AM
Quote - Mike, you might take a look at the ShaderWorks Library Manager, it might suit you better than Poser's built-in library.
Cheers.
Hmm, remember seeing it and thought it was for poser 8 and 2010, will see if it was updated, thanks.
Regards, Michael
My DeviantArt page
Sharkbytes-BamaScans ( ) posted Mon, 15 April 2013 at 1:35 PM
I know this isn't the thread for it.. but just showing off my first poser render in over a year.  Thanks Paolo for R3 giving me the nudge to open back up a program I spent six years of my life with.
Pret-a-3D ( ) posted Mon, 15 April 2013 at 1:37 PM
Thank you Sharkbytes.
I guess we should open a thread in the Poser forum :)
Paolo
Tw: @preta3d
bobvan ( ) posted Mon, 15 April 2013 at 2:29 PM
I have gotten those jagged shadow from the sunlight I usually post work them out...
Sharkbytes-BamaScans ( ) posted Mon, 15 April 2013 at 2:43 PM · edited Mon, 15 April 2013 at 2:44 PM
Bob.. I considered it.  But, I chalked it up to lessen learned and will be working with the softness of my shadows more in the future.  The reason I didn't postwork them out is that I didn't want to detract from the quality of the skin texture on her.  Blurring, cloning or smudging would have ruined her skin in a few places.
mustang2011 ( ) posted Mon, 15 April 2013 at 4:07 PM
Quote - Bob.. I considered it.  But, I chalked it up to lessen learned and will be working with the softness of my shadows more in the future.  The reason I didn't postwork them out is that I didn't want to detract from the quality of the skin texture on her.  Blurring, cloning or smudging would have ruined her skin in a few places.
Can't say for sure how to fix the jagged edges in Poser, I just know how to fix it in Reality 2.5.
I usually raise the subdivide on the parts of the skin and it takes care of the jagged edges. Works too on outfits.
bobvan ( ) posted Mon, 15 April 2013 at 4:10 PM
Will give that a try thanks
bobvan ( ) posted Thu, 18 April 2013 at 7:08 PM
Oooaa no win 8 for now my vid card does not have compatible drivers....
UHF ( ) posted Thu, 18 April 2013 at 8:38 PM
Quote - Oooaa no win 8 for now my vid card does not have compatible drivers....
You know you're on the bleeding edge when....
bobvan ( ) posted Thu, 18 April 2013 at 8:42 PM · edited Thu, 18 April 2013 at 8:42 PM
Quote - > Quote - Oooaa no win 8 for now my vid card does not have compatible drivers....
LOL just wasted a week due to waiting to get this upgrade (or downgrade depends who you ask) done ho well
john3d ( ) posted Fri, 19 April 2013 at 7:42 AM · edited Fri, 19 April 2013 at 7:43 AM
Just thought I'd let you all know that the lamp set I made has been tested and is now available for you to a have a play, I post a note a few pages back but Paolo release Reality3 around the same time so you may have missed it.
Just click on my the banner and have a look see.
Many thanks to Kim for testing the lights for us.....
Pret-a-3D ( ) posted Fri, 19 April 2013 at 8:38 AM
FSMCDesigns ( ) posted Fri, 19 April 2013 at 2:08 PM
Nice work John! Outstanding quality
Regards, Michael
My DeviantArt page
JV-Andrew ( ) posted Fri, 19 April 2013 at 2:22 PM
Thanks for the lights john3d, just dowmloaded them  :)
[url=http://jv-andrew.deviantart.com/]My deviantART page[/url]
[url=http://www.sharecg.com/pf/full_uploads.php?pf_user_name=Jabba101]My ShareCG freebies[/url]
[url=https://soundcloud.com/jv-andrew]Some of my music[/url]
medmon ( ) posted Fri, 19 April 2013 at 3:14 PM
John, thanks for the lamps, another excellent set of props from WDJ :)
john3d ( ) posted Sat, 20 April 2013 at 1:44 AM
Thank you, you are most welcome.
bobvan ( ) posted Sat, 20 April 2013 at 3:00 AM
bobvan ( ) posted Sat, 20 April 2013 at 9:57 PM
