Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 03 6:32 am)
.obj export should work as import in Vue 10 as long as you export from Poser 9 or Poser Pro 2012 (latest SR). When importing to Vue you need to manually find the textures (in the DAZ folder inside Runtime). Vue should ask you for the location. Alternatively you can copy the texture files into the same location as the .obj. Once the horse is imported, open the group in Vue. You will see that in addition to all the usual body parts you also have one labled _SUBD. This is the subdived mesh that you want to use in Vue. You can hide or delete all the other body parts (but kep the teeth and eyes!).
Ciao
TD
still have some problems first off I am using poser 2012 fully up to date and DAZ horse 2 works perfect in poser (dont use DAZ studio) if i export as object and then open in vue , having put copies all the content of the DAZ horse 2 materials in to the same folder vue starts to ask for files that arnt in ther eg horse 2 eyelashes trans MH2 any idear where these are?
I would like to know if it's possible to use Daz horse 2 in view? Normally I just save a post character as Poser scene and import object in view, but seem to be running in to problems, is it even possible to use it in view I know it had a DSON file to make it work in poser is that the problem? Any help would be much appreciated
