Mon, Nov 25, 1:20 AM CST
Subject: "Poser executable file has stopped working"
Casette ( ) posted Sat, 04 May 2013 at 7:07 AM · edited Sun, 24 November 2024 at 11:27 PM
Hi folks
Houston, we have a problem. Poser 8 and Windows XP. Rendering a scene the f****** Poser crashed, and now when I hit the Poser icon I receive inmediately the message "Poser executable file has stopped working" for three times and... nothing more
I reinstalled Poser 8 and no changes. Obviously I've restarted the computer lots of times. HELPPPPP!!!
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
MikeMoss ( ) posted Sat, 04 May 2013 at 7:20 AM
Hi
Uninstall Poser and then run CCleaner registry scan to get rid of left over junk.
Then try reinstalling it again but don't install it to the same directory.
You are probably picking up something corrupt from the previous install.
If you put the program in a different location Windows will see it as something new and ignore previous installs.
You can install it in a folder named New Poser Install outside of the Programs folder or where ever you want.
Mike
If you shoot a mime, do you need a silencer?
Casette ( ) posted Sat, 04 May 2013 at 7:26 AM
Thanks. I'll try it
CASETTE
vilters ( ) posted Sat, 04 May 2013 at 7:41 AM
Removing only Poser's preference files often helps.
Poser creates a new set on next startup.
Search for Poser.ini and delete that folder and all its files only.
markschum ( ) posted Sat, 04 May 2013 at 6:10 PM
I would do a cold boot first. (power off  and restart) That should ensure all memory is cleared and any cached files are read again from disk.
WandW ( ) posted Sat, 04 May 2013 at 9:37 PM
Quote - Removing only Poser's preference files often helps.
Don't delete Poser.ini! Rename it.  If you delete it and it's not the problem, you have lost your settings.  If renamimg it solves the problem you can selectively paste important settings back in.....
Casette ( ) posted Sun, 05 May 2013 at 3:39 AM
Easier. I tried to reinstall Poser again, but this time I chose "remove existing preference files" instead of "use existing preference files" that was my previous choice. Poser opens and it's working again!!!!!!!!!!!!
Thanks to all :)
CASETTE
vilters ( ) posted Sun, 05 May 2013 at 3:43 AM
See, it builds a new set of preference files.
Happy Posering
Tony
basicwiz ( ) posted Sun, 05 May 2013 at 11:38 AM
I'm just taking a stab in the dark here...
You wouldn't, by chance, have your pagefile turned off in windows would you? If you do, turn it back on and see if the behavior goes away.
I was one of the idiots who took bad advice on the internet and turnbed the pagefile off. My 20 Gig ram computer choked on a huge render I was doing... turning pagefile back on fixed it right up.
