Fri, Nov 22, 7:27 PM CST
Subject: CHECK THIS OUT !!!!!!!!!!!!!!
vilters ( ) posted Wed, 22 May 2013 at 5:36 AM · edited Wed, 22 May 2013 at 5:37 AM
The first one would be required no? :-)
You want the new cartoons? Cartoon file needed.
You want Rex and Roxie hair? hair file needed
You want Rex and Roxie clothing? clothing file needed
You want Rex aand Roxie? Nude figures needed
You want faceroom support?  Support files needed
You want Rex and Roxie clothed figures? Clothed figures file needed
Props and scenery ? If you want them?
Animals?
3doutlaw ( ) posted Wed, 22 May 2013 at 9:42 AM
For the new fitting room, would it have the same problems working with a conforming clothing item as the cloth room did?
For example, when I have tried to convert a conforming figure (jacket for example) to an OBJ, and it often falls apart in the cloth room (i.e. as a conforming outfit it did not appear to be needed to be welded together, etc)
AmbientShade ( ) posted Wed, 22 May 2013 at 12:29 PM
Quote - The first one would be required no? :-)
Animals?
Thanks.
I went ahead and got it all anyway. I'll go through and delete 90% of it tho since I don't use it, but the masters will be stored on my external as back-up. And probably on dvd as well just to be safe.
~Shane
ErickL88 ( ) posted Thu, 23 May 2013 at 11:28 AM
One quick question.
Do we still get these (sometimes smaller, sometimes bigger, depending on you render settings) darker/black blotches in our renders, when using light emitters, with IDL and IC enabled?
