Mon, Nov 25, 6:53 PM CST
Subject: Lampshade and Inverse Square Attenuation
  • 1
  • 2
stewer ( ) posted Tue, 04 June 2013 at 9:43 AM
That's why there's a checkbox next to gamma correction - it's an option, not a requirement. Whatever gives you the result that you're looking for is the way to go.
Cage ( ) posted Tue, 04 June 2013 at 10:56 AM · edited Tue, 04 June 2013 at 10:58 AM
Quote - That's why there's a checkbox next to gamma correction - it's an option, not a requirement. Whatever gives you the result that you're looking for is the way to go.
And thank you very much for including that box.  :thumbupboth:  If you guys ever want to chase me away from Poser, get rid of that box and force people to use GC all the time.  That box is my friend.  It tells Poser that I meant exactly what I said, when I set up that shader.  I didn't mean give me some weird color that's vaguely similar, but not quite the same, then fight me when I try to work back toward the proper color.
Your post was civil and I'm just kvetching.  Can I ask, at least, why does GC change colors that I've entered as nodes?  I plug into a colorramp and GC changes what I've set on the node.  Shouldn't there at least be a selective OFF switch for that?  Without disabling GC altogether and thus having screwy lights?  There's something similar for texture maps.  Why not for specific nodes, or full materials?  So Poser will accept that I meant what I told it?
I'm kvetching again.  Sorry. I'm in a foul mood about other things and I'm transferring.  That's not fair.  You guys do good work, and GC is a great addition.  I have the sense, though, that it's doing a bit more than advertised.  In addition to compensating for monitor gamma, it's trying to fix that fact that Poser's lights have always been wrong somehow.  As a consequence, the entire materials flow of Poser is disrupted when GC is utilized, and presumably future rendering advancements will be GC-dependent.  It really looks like a feature that is only partially implemented so far, to me.  But I'm a know-nothing and a grouch.
Thanks for your help, Stewer, and everyone.  While I'd like to have the one or two actual questions I may have raised above answered, I'd also kind of like to let this thread die a death.
JoePublic ( ) posted Tue, 04 June 2013 at 3:40 PM · edited Tue, 04 June 2013 at 3:52 PM
Online Now!
I'm just posting this mainly for myself because I wanted to finish the work I''ve started.
The problem is, can I make my shader look "Non-Gamma-y" but with Gamma correction enabled ?
I think, yes.
First picture shows a Gamma vs Non-Gamma comparision.
The lights have been adjusted of course, as you can see by the fact that the skin shader looks the same on both.
As I said earlier, you need non-GC lights for non-GC renders and GC-lights for GC-renders.
So, left is GC, right is non-GC.
Without GC, the Lurex shader has a lot more contrast and pitch-black "darks".
JoePublic ( ) posted Tue, 04 June 2013 at 3:43 PM
Online Now!
By adjusting highlight and sparkle color as well as edgeblend, I made "darker darks" and compensated for the GC "Washout".
Both rendered with GC on. Left new shader, right the old one.
Cage ( ) posted Tue, 04 June 2013 at 4:26 PM · edited Tue, 04 June 2013 at 4:27 PM
Hey, Joe.  I like you, I like your work, and I do thank you for your efforts with that shader.  But talking about it here is merely misleading.  It's a nice enough shader, but, as you noted, it is simple.  It is remarkably similar to half a dozen shaders I tried for this purpose way back in the P5 days, and then discarded.  In short, it is a nice enough shader, it renders tolerably well in the context you show, but it does not resolve the problem I noted on page one of the thread.  The effect I need still defies GC conversion.  As I worked with your shader, it began to have the same problems with GC as I gradually approached a result I liked better.  Then, big surprise, it behaved as I wanted once GC was off.
I'm afraid I will keep responding when the thread is bumped, and I'll probably be a turkeyhead.  Please let me kill the thread I started without my resorting to trying to get it locked or deleted.
I hope I do not offend.  That is not my intent.
millighost ( ) posted Tue, 04 June 2013 at 7:06 PM
> Quote - I'm just posting this mainly for myself because I wanted to finish the work I''ve started. > > The problem is, can I make my shader look "Non-Gamma-y" but with Gamma correction enabled ? > > I think, yes.
In cases where the shader does not contain any transparency (like the lurex from above) this is very straight forward.
1 Replace the multiple inputs on the PoserSurface node with a single input by adding them together (left illustration). This gives the original (non-gc) render (lower left). I do not know why there is no dark shadow in it, like in cage's example; but Poser complained about the material file's version (i have poser 2010), perhaps it has something to do with it. Anyway, for illustration purposes i do not care what the shader does, only that it stays the same. I only removed the bump and displacement (not interesting enough) and the texture map (because i used the sphere, not a batman costume).
2a To convert for gamma correction: Take the output of the Add to the power of 2.2 (the gamma value). This reverses the effect poser will apply to the final output of the render.(right side)
2b Go through every color chip on every node and apply the inverse gamma function to it. E.g. if a color value has RGB = (202, 86, 242) set it to (229, 156, 249) (because (202/255)^(1/2.2)*255 = 229 and so on. This reverses the effect gamma correction will have on the color chips.
The resulting render with GC enabled is in the lower right. Still does not look great, but does look the same, more or less. In theory it would be exactly like the one without gamma correction, in practice there will be slight differences because of the filtering the renderer does. (This procedure will be slightly more complicated when the shader contains reflection or refraction and practically impossible when it contains transparency, though)
Cage ( ) posted Tue, 04 June 2013 at 7:13 PM · edited Tue, 04 June 2013 at 7:14 PM
Hey, wow.  I will not throw a fit about the thread not dying, because I think this is actually useful.  Millighost, are you illustrating an Off switch for gamma correction on select materials?  If so, you are my current Poser Hero.  Someone slap that method into a wacro.  Well done.  :thumbupboth:
But, seriously, I would kinda like the thread to die.
moogal ( ) posted Tue, 04 June 2013 at 7:52 PM
Quote - The trouble being that I get the sense that Poserdom is moving in the GC direction.  How many updates before GC is the only option, with "normal" rendering removed, just as old P4 rendering was?  That may be the day when I walk away from Poser, or I may be forced to finally work with it.  Maybe.
Poser is dumbed down in so many ways, but here it tries to force people to do it the smart person way.
I'd say it would be best to work with it.  It was added for a reason, because too many things in Poser were dumbed down or hacked and it was ultimately holding everyone back.  When Pro was introduced you can see the trend of trying to do more things right rather than simply, and these changes really had to be made to both versions of Poser as they share content.  My experiences have shown that since GC was added everything I've made from scratch looks better.  Unfortunately that means all of my old stuff does look worse.  GC just requires a different set of assumptions about how things will ultimately look, but similar results seem possible.
Cage ( ) posted Tue, 04 June 2013 at 9:30 PM
Quote - > Quote - The trouble being that I get the sense that Poserdom is moving in the GC direction.  How many updates before GC is the only option, with "normal" rendering removed, just as old P4 rendering was?  That may be the day when I walk away from Poser, or I may be forced to finally work with it.  Maybe.
I'm all for Poser ending the dumbing-down, in most areas.  I would prefer it, generally.  In this case, not so much.  How many of us can throw around the math that bagginsbill makes seem so simple?  I know I can't.  If mathematically "correct" shaders are to become a requirement, there needs to be a tool to make them accessible.  And some damned better example shaders in the library.  The examples in there now?  Not correct!  Buzz, wrong answer.  And a manual for Firefly.  Seriously, right now we get the RTFM attitude from certain quarters, when there's no manual.  Right now we learn from a slew of forum posts (when the links aren't dead), strewn across two, maybe three forums.  Forums with dodgy search functions, some of which don't mind breaking their links and leaving you without the images and examples you need in order to make sense of a materials-related discussion.  That's no good.
So I've been having a hissy fit about this.  Had a few bad days, this is badly timed, sure.  Yet from my perspective, I think I have a pretty good reason for it.  Stick me in a contradictory situation, I react badly.  Why is my lighting screwy, I ask, and away we go.  Hey, you now need to use GC now to have proper lighting.  Great.  But using GC breaks your shaders.  They don't represent what they're supposed to anymore, no longer say what you meant them to say.  Simultaneously, using GC breaks the WYSIWYG principle of the Materials Room.  Try repairing a broken shader developed by eyeballing it, because you aren't bagginsbill, while you can't see what you're doing, colors don't mean what they should, attenuation behaves oddly, falloffs are screwy, and you can't quite see what you're doing.  Meanwhile, GC fights your every effort to restore your desired effects.  So you have a complicated, broken shader, and the tools you need to fix it have been taken away.  And, remember, you aren't bagginsbill.  And you can only turn off the effect globally, but that breaks the lights, so don't do that.  And everyone is pushing GC like it's the greatest thing ever, prompting you to use it, ignoring the fact that the use of it creates an unworkable mess in the Materials Room.  No problem here.  I found it easy to adjust.  You will, too.  Oh, but all my shaders are pretty simple, I never really tried to push the Materials Room much, and all of my shaders were a piece of cake to fix.  Yep.  And the proposed solution is backtracking to rebuild everything from scratch.  Step back ten years and start over with simple stuff from the Dawn Age of Firefly.  Sorry, that's a crap situation.  Absolute pants.  Rubbish.  That's situation resulting from a feature which isn't fully ready yet.  Poser has a long history with those.  How long did it take the Morph Brush to be stable and reliable?  And the Hair Room still sits there, waiting to be put into a useful state, 10+ years later.  I don't mind Poser's unfinished features, largely, but then Poser and Poserdom don't try to force me to use them, generally.  Sit back, wait a few versions, maybe the gamma correction will be properly integrated with the Materials Room, WYSIWYG restored, and I can work with it.  Until then, it's tacked on, with only the surface functions working as needed.  Unless you're bagginsbill or a reasonable facsimile, or you're one of the programmers, or you're using simple materials, or you're working from a recipe.
If I can disable it when needed, I will use it where it is useful and shut it off where it isn't.  I mean what I say, when I tell a shader to do something.  Those colors I plugged into that node?  Those are what I actually want.  That overblown highlight?  Intentional.  That exaggerated darkness around the edges?  I meant to do that.  I don't want some automatic feature changing it.  Alternately, if the Materials Room once again lets me see what I'm doing so I can fix things, I will be ready to experiment, with an eye toward using the feature if I can get the results I need.  So far my experiments show that I just need to shut the thing off.  As Stewer points out, I can do that, so sit down and shut up, me.  Oh, except that breaks the lights, doesn't it?  Yeah, forgot that.  You can turn it off, anyway, until it's made an actual requirement, and it looks like that's not unlikely.  And you can't ask materials-related question at the forums any more, because the main answer will always be that you need to use GC.  That's you're problem.  hey, you're not using the GC.  Hey, finish it and I will perhaps use it.  Until then, I seek an off switch, whether global or specific to select materials.  I honestly don't need it.  I'd like lights that work properly, but, hey.
Poser has some great things to offer.  If I'm going to struggle with something, it should be a feature I like, not an effort to re-learn the Materials Room for no really good reason.  Again, phooey.  Also, phooey on articulate responses with sensible paragraph structure.  Bah!
Cage is an asshat, and stubborn, and doesn't have much patience for some types of nonsense.  Fair enough.  Just be glad you don't have to live with him all the time.  It's no picnic, lemme tellya.
  • 1
  • 2
