Wed, Nov 13, 9:23 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: hide skin lines....
xpdev ( ) posted Mon, 17 June 2013 at 1:32 AM · edited Tue, 12 November 2024 at 2:05 PM
Time ago i have read something about hide connection skin lines (see picture) on low resolution renderings ....
me i'm wrong ???
someone remember something about ?
thanks
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
vilters ( ) posted Mon, 17 June 2013 at 2:20 AM
In the materail room;
set texture filtering to "crisp" in all image map nodes. (It is at the bottom)
xpdev ( ) posted Mon, 17 June 2013 at 2:27 AM
Ok, many thanks.
i'll try
icprncss2 ( ) posted Mon, 17 June 2013 at 6:35 AM
Lowering the minimum shading rate in the render settings is another way.  By default it's set a 1.  Lowering the minimum shading rate can increase render times by a bit.
cedarwolf ( ) posted Mon, 17 June 2013 at 10:13 AM
Interesting.  I've been having that same problem with some of the textures I use, now I have an idea of what to do.
vilters ( ) posted Mon, 17 June 2013 at 10:43 AM
Just an extra tip:
Never-ever put texture filtering to "none".
You loose texture caching that way. => In General preferences.
Always set texture filtering to quality or crips.
Crisp being the preferred method.
Bill1200 ( ) posted Mon, 17 June 2013 at 6:32 PM
What's the difference between crisp and quality? Is crisp done by adding sharpening?
hborre ( ) posted Mon, 17 June 2013 at 7:15 PM
Crisp is an additional setting introduced in Poser 9/PP2012 which is another sharpening step for textures
Cage ( ) posted Mon, 17 June 2013 at 8:32 PM
Quote - Just an extra tip:
A special case can exist for (at least some) transparency maps, apparently.  Because Poser.  :lol:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2862631&page=2
hborre ( ) posted Mon, 17 June 2013 at 8:43 PM
I would also think that background props and models could use texture filtering at none to enhance DoF for those renders incorporating camera aperture control.
mackis3D ( ) posted Mon, 17 June 2013 at 11:29 PM · edited Mon, 17 June 2013 at 11:29 PM
The lines on skin also appear sometimes if the displacement maps are too strong. But they're not white lines then but rather very small black lines.
mackis3D ( ) posted Mon, 17 June 2013 at 11:52 PM
What has texture caching to do with texture filtering? And why is it lost that way?
