Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 3:31 pm)
You might want to try this after you conform:
Select the clothing
Choose Figure > Zero Figure (returns the clothing to zero pose)
Choose Edit > Memorize > Figure
Now your figure should be zeroed and memorized and should conform properly. Save to the library.
If this doesn't fix the problem let us know
That didn't work. I loaded both Miki4 and Miki4 DevRig, and zeroed both. Odd thing, is that Miki4 has a -0.043 translation in the Y-axis, even after zeroing. Before zeroing, she had a 2 degree rotation in the X-axis, and her hip has a 4 degree rotation in the X-axis. This is on a fresh install of Miki4, so I don't know if a ticket is needed at SM, or can I tweak the CR2 file?
Thanks, -Starkdog
Here's what I get with both the dev rig and the finished version of Miki4 both loaded and zeroed
One thing though ... when zeroing Miki4 (the full one, not the dev rig) make sure you have HER selected rather than her eyelashes.
what's going on with her left shoulder? back view
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
kinda looks like a train tunnel.
I've never rendered Miki3 from the rear. now i'm gonna worry until i can go home and test render.
