Fri, Nov 22, 8:35 AM CST
Renderosity Forums / Freestuff
Welcome to the Freestuff Forum
Forum Moderators: wheatpenny, RedPhantom Forum Coordinators: Anim8dtoon
Freestuff F.A.Q (Last Updated: 2024 Nov 17 8:21 pm)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all  freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered.  Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
Free Stuff Guidelines
Subject: No Ears
arrowhead42 ( ) posted Sun, 07 July 2013 at 2:44 AM · edited Fri, 22 November 2024 at 7:59 AM
Does anyine know where I might find a working "no ears" morph for M3? I downloaded such a morph from
http://www.renderosity.com/mod/freestuff/details.php?item_id=49081
But it doesn't work.
Thanks -
Here's the link to my freebies:   https://www.renderosity.com/mod/freestuff/?uid=493127
My cousin Jack can speak to beans. That's right.... Jack and the beans talk
Alisa ( ) posted Sun, 07 July 2013 at 10:06 AM
I googled "m3 no ears morph" and found this
http://www.sharecg.com/v/23440/
Does that help?
Cheers,
Alisa
RETIRED HiveWire 3D QAV Director
wyrwulf ( ) posted Sun, 07 July 2013 at 10:23 AM
> Quote - Does anyine know where I might find a working "no ears" morph for M3? I downloaded such a morph from > > http://www.renderosity.com/mod/freestuff/details.php?item_id=49081 > >   > > But it doesn't work. > >   > > Thanks -
That one works for me.
arrowhead42 ( ) posted Sun, 07 July 2013 at 1:28 PM
Aproctor, I found that too, but they're only .obj files. I'm not sure how to use them....
Wrywulf, what did you do? Just shrink the ear size?
Alisa ( ) posted Sun, 07 July 2013 at 6:03 PM
Arrowhead - are you using DS or Poser?
Cheers,
Alisa
wyrwulf ( ) posted Sun, 07 July 2013 at 10:20 PM
The no ears morph is an injection pose in RuntimelibrariesPoseM3 No Ears when installed from the zip. I loaded M3, double clicked the No Ears INJ and the morph loaded at 1 with the ears gone, the image on the right. The image on the left is with the morph set to -1. The morph is under the Body and the Head. The morph loads with the body dial set to 1. If you turn both, they will work together and make the morph not work how you want.
arrowhead42 ( ) posted Sun, 07 July 2013 at 10:57 PM
Alisa, I'm using Poser
Wyrwulf, when I downloaded that .zip file, the only things in it were the following files
M3-no-earsINJ.pz2
M3-no-earsREM.pz2
I think something's missing. It seems to me that there's some other file(s) that are supposed to be there as well.
I followed your steps - the same thing I did last night - and got the same results. Nothing. No morph shows up in either the head or body hierarchy
wyrwulf ( ) posted Sun, 07 July 2013 at 11:43 PM
It sounds like you have a settings issue with your unzip program. There should be a setting to extract with relative paths. If you still have the four files, you can put them in one of your pose folders, and they should work.
wyrwulf ( ) posted Mon, 08 July 2013 at 6:57 AM
Here is an image of the folder tree I get when I unzip with relative paths enabled.
arrowhead42 ( ) posted Mon, 08 July 2013 at 11:32 PM
I just did that, and now the morph dial at least shows up in the list of morphs when I load M3. It didn't even do that before. But the morph doesn't work.
Y'know, I give up. I just give the @#$%^&* up.  I really do.
For the last month, since I switched computers to something that at least runs with speed and reliability, I've had nothing but problems with anything related to 3D. UV Mapper Pro won't run in Windows 8, half my textures didn't show up when I transferred stuff off my old PC, and now this.
This must be a sign that I need to find something else to do with my time. Sorry, I'm not taking it out on you, but I'm just so fed up and disheartened by one problem after another that I don't think I can take it anymore.
Alisa ( ) posted Tue, 09 July 2013 at 12:16 AM
I'm sorry you're having such trouble.  I know this can be frustrating :(
If you want to try the obj files, here's how:
Bring in your figure
Select the head
Click OBJECT/LOAD MORPH TARGET
Click on the little box with ... on it and then find the obj file
The Label will change to the name of the obj.
  Check box "attempt vertex order correction" At least you may have to check that :)
Click OK
There should be a new dial under Morph in the parameters section for the head.
Hope that helps
Cheers,
Alisa
arrowhead42 ( ) posted Tue, 09 July 2013 at 1:04 AM
Thanks Alisa - I'll give it a try tomorrow. I'm heading off to bed. It's 1am where I am, and I think I'm finally tired enough to sleep. I hope so.... gotta be up for work at 7am.
Thanks again -
Steve
Alisa ( ) posted Tue, 09 July 2013 at 11:22 AM
You're welcome.  Hang in there! ;)
Cheers,
Alisa
arrowhead42 ( ) posted Tue, 09 July 2013 at 11:47 PM
I just tried it, and when I loaded the morph target and clicked "OK", I got an error message that said "Target geometry has the wrong number of vertices".
So in spite if the fact that this figure is M3 from Daz, and the morph targets are made for M3, it's telling me that M3's head is made up of too many or too few vertices.
See. That's what I mean. It should work, but it didn't. Just one more thing wrong somewhere...... One aggravating problem after another. After another. It never stops.
Alisa ( ) posted Wed, 10 July 2013 at 12:07 AM
Quote - I just tried it, and when I loaded the morph target and clicked "OK", I got an error message that said "Target geometry has the wrong number of vertices".
It did that to me when I didn't check the box "attempt vertex order correction" like I mentioned.  But it didn't when I checked the box.  I'm using Poser Pro 2012 so don't know if it's different in other versions.
Cheers,
Alisa
