Wed, Feb 12, 7:36 PM CST
Subject: pp2014 Tx peculiarirty
luckybears ( ) posted Sun, 14 July 2013 at 8:29 PM · edited Wed, 12 February 2025 at 6:48 PM
Be grateful to know what is happening here. The textures applied are the same but the pp2014 splits it diaginally. I used the same prop
ghostship2 ( ) posted Sun, 14 July 2013 at 8:41 PM
Online Now!
I would try checking normals forward and also find out if that prop is two sided or one sided. probably better to be one sided.
luckybears ( ) posted Sun, 14 July 2013 at 8:51 PM · edited Sun, 14 July 2013 at 8:53 PM
The prop is DS, one mo' and I'll try it OS.----Just the same with a single side prop :(
TrekkieGrrrl ( ) posted Mon, 15 July 2013 at 10:17 AM
Is this rendered or perview?
ghostship2 ( ) posted Mon, 15 July 2013 at 10:52 AM
Online Now!
have you tried changing texture coordinates on the image map? I think this is normaly set to UV.
luckybears ( ) posted Mon, 15 July 2013 at 7:01 PM
I just rendered it in pp2014 and it came out as it should, TG :) The texture coords are set to UV, ghost. I tried all the otions but in preview the tx remains diagonally malforemed and it's difficlut setting up the scene using pp2010.
 TY for replies
markschum ( ) posted Tue, 16 July 2013 at 9:50 PM
Have you used scaling or offsets in the image node ?  preview does not display those correctly in versions to P7.
