In the advanced material room settings
Transparency = 1
Every other setting = 0
Poser Ambassador;
Poser 11 & 12 / DS4 / Metasequoia / Silo / Zbrush / realityPaint / UVMapperPro / XD 4
/ Ps CC / Fw / Ai / Painter 12 / Clip Studio Paint / Comipo /
Reality 3 / Windows 10 /
Units = Poser Native
Are you using AO?
Poser Ambassador;
"That's what I have"
You have Transparency_Falloff set to 0?
A lot of people don't pay attention and leave Transparency_Edge at 0 (which is opaque) and Transparency_Falloff not zero. This would cause it to be visible.
You should check every light and make sure that AO is not on. (although that shouldn't create your problem.)
If all of that is 100% the same in the advanced material settings, then you should double-check the eye texture itself.
Poser Ambassador;
To make this even easier, I'm attaching an MT5 file for use in Poser.
Anyone who runs across this file is free to redistribute it; just don't modify it.
Poser Ambassador;
Oops, I can't upload an MT5 file on the forums. Sorry.
Poser Ambassador;
Rename the file .mt5.txt and you can upload it. Then downloaders just have to remove the .txt to get it back as an .mt5.
Thanks, BB. Helpful as always. :)
Poser Ambassador;
Quote - Transparency_Edge at 0 (which is opaque) and Transparency_Falloff not zero.
When Transparency_Falloff is zero (as it is in andolaurina's material screen shot above), the Transparency_Edge value is ignored and does not affect anything.
Transparency_Falloff (if non zero) says that the transparency is a blend between the two transparency values that preceed it.
The blending is based on Edge_Blend, and the falloff is actually the same as Edge_Blend Attenuation.
In non-math terms, it means shift the in-between values more or less towards the edge.
In math terms, the blending coefficient is:
cos(angle_of_incidence) ** Transparency_Falloff
It seems no matter how i change the settings it still wants to show up as a black line when i render... very faint but nevertheless incredibly annoying. How do i make the tears 100% invisible?
This is V4 in PPro 2012
Thanks!
