Sat, Feb 8, 4:22 PM CST
Subject: reflection color from an image?
ghostship2 ( ) posted Mon, 22 July 2013 at 1:51 AM · edited Fri, 07 February 2025 at 6:02 AM
Im trying to texture the M3 Apollo space suit and cant figure out how to use a texture map as the reflect color for the vavles.. see image. Ive tried to plug the map into the reflect node several different ways and none work to get the effect that plain old reflect color gets.
ironsoul ( ) posted Mon, 22 July 2013 at 2:57 AM
The softness value is high, is that what you intended?
ashley9803 ( ) posted Mon, 22 July 2013 at 3:19 AM
Are you after a simple red glossy/shiny reflect or a radiosity effect, where the red is reflecting light diffusely onto other objects? The former should be easy with a red specular value, the latter requires IDL rendering. Are the valves a separate material zone to the rest of the suit?
millighost ( ) posted Mon, 22 July 2013 at 8:17 AM
> Quote - Im trying to texture the M3 Apollo space suit and cant figure out how to use a texture map as the reflect color for the vavles.. see image. Ive tried to plug the map into the reflect node several different ways and none work to get the effect that plain old reflect color gets.
You could simply multiply the reflection with an image texture map (see illustration).
hborre ( ) posted Mon, 22 July 2013 at 8:42 AM
Online Now!
Background on the reflect node should be black unless you are intend to plug an image into it.
SamTherapy ( ) posted Mon, 22 July 2013 at 11:51 AM
BTW, the valves shouldn't all be red.  Some of 'em are blue on the real thing.
bagginsbill ( ) posted Mon, 22 July 2013 at 1:22 PM
ghostship2 ( ) posted Mon, 22 July 2013 at 9:11 PM
Millighost's suggestion worked. here is what Ive got so far.
