Fri, Nov 22, 12:23 PM CST
Subject: Shadows trouble.
xpdev ( ) posted Thu, 25 July 2013 at 11:38 AM · edited Fri, 22 November 2024 at 7:01 AM
look at this rendering, the parties with the red arrow have a strange shadow, I can not solve the problem.
Do not mind the dots above her shoulders, I solved that problem
The lights are on the right and above, no left except natural reflection on the wall
if I add a little light on the left the problem goes away, but then the scene is no longer consistent.
you have any ideas ?
thanks.
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
markschum ( ) posted Thu, 25 July 2013 at 2:36 PM
I dont see anything wrong with the pic without knowing exactly where the lights are.
You could use a light as a fill without shadows if you prefer that.
Are you using any ambiant occlusion ?
xpdev ( ) posted Thu, 25 July 2013 at 2:51 PM
No, i use GC and IDL so no AO
in my renderings.
bevans84 ( ) posted Thu, 25 July 2013 at 4:10 PM
IDL automatically adds AO. In fact, if you use D3D's Render Settings to set the IDL level, it applies the same amount of AO regardless of the level setting.
xpdev ( ) posted Thu, 25 July 2013 at 4:57 PM
Are you sure that with indirect light poser automatically add AO ?
This may be my problem in rendering above ?
bagginsbill ( ) posted Thu, 25 July 2013 at 6:52 PM
9/10 chance it's a baked in shadow on the lower part of the breast. Did you have a look at the color map?
Almost every map I look at has lighting baked into the breast there, and this causes grief in an otherwise accurate 3D simulation.
R_Hatch ( ) posted Sat, 27 July 2013 at 12:12 AM
The correct, scientific term is "boobshadow", as in: "I would have bought that character pack, were it not for the textures suffering from obvious boobshadow."
Not to be confused with the similar problems of "buttshadow" and "noseshadow". Oddly enough, I'm not anywhere near as annoyed by "earshadow", although it is also bad practice.
nightwolf1982a ( ) posted Sun, 28 July 2013 at 7:00 AM
Have you checked the bump map?  It looks like you have a really high bump map setting.
