9/10 chance it's a baked in shadow on the lower part of the breast. Did you have a look at the color map?
Almost every map I look at has lighting baked into the breast there, and this causes grief in an otherwise accurate 3D simulation.
The correct, scientific term is "boobshadow", as in: "I would have bought that character pack, were it not for the textures suffering from obvious boobshadow."
Not to be confused with the similar problems of "buttshadow" and "noseshadow". Oddly enough, I'm not anywhere near as annoyed by "earshadow", although it is also bad practice.
![file_496669.jpg](https://live.cdn.renderosity.com/forum/threads/2870479/file_496669.jpg)
look at this rendering, the parties with the red arrow have a strange shadow, I can not solve the problem.Do not mind the dots above her shoulders, I solved that problem
The lights are on the right and above, no left except natural reflection on the wall
if I add a little light on the left the problem goes away, but then the scene is no longer consistent.
you have any ideas ?
thanks.
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
