Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Then it is a matter of adding a mask
This is the simplest way of doing it. Now you can modify the glass as you wish
See example
Math node is a simple substract to get the inverse
Fresnel is the standard default fresnel
The texture node contains the movement of the lettering to get it into position
Quote - You need a glass which is uvmapped to position the letters
See example
Did that ;). But thanks. :)
Quote - something like this: you need inverted maps...one for the stuff you want to be reflective/refractive and one inverted version of that for the defused lettering/lable
I do have a mask and I did use it inverted, however - the glass mat I'm using uses the reflect, refract and the alt specular. Like I said above, I made a label material, made the stuff I didn't want transparent and I can do whatever I want with the letters. Problem solved ;). Won't work with some stuff, but in this case, it worked well.
You know how to make a glass that goes into Alternate_Diffuse, right?
You know how to make a paper or paint or anything that goes into Alternate_Diffuse, right?
So - you have two shaders - glass and paper (or whatever) - each resulting in one node that goes into Alternate_Diffuse.
Combine them with a Blender node, and run your mask into the Blending factor. The Blender goes into Alternate_Diffuse.
PS - Because of Poser's internal refraction mistakes and/or deal with thin glass, I don't use the Fresnel node. To simulate thin glass, build it up from reflect+refract+fresnel_blend and use different IOR in the refract to get it to behave.
I am using PP2012 and what I need is a clear glass material (for a bottle) that I can add a label to (plain text alpha map) and be able to make that text any color and/or a metallic.
I have a bottle and the liquid inside must show thru the glass (the liquid is a separate object and the bottle glass has thickness).
I've been trying all afternoon to knock the label out of the glass material with its own flat color and tried metallic too, but I keep bombing ;).
Any help would be appreciated :).
