Sun, Feb 16, 11:59 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Subject: how to make swords look real
Youngdeathknight ( ) posted Mon, 02 September 2013 at 9:52 PM · edited Sat, 08 February 2025 at 11:24 PM
I am just a beginner, but how do you load textures to make Onmi Swords look like actual swords? I don't know if it is in the material room....
Thanks.
Youngdeathknight ( ) posted Mon, 02 September 2013 at 9:57 PM
oh my apologies; it's omni
TrekkieGrrrl ( ) posted Mon, 02 September 2013 at 10:20 PM
more explanation is needed.
first of all: Which Poser version.
Then, you'll need a good metal texture, and almost as important, something "outside" the scene, like an environment dome (I personally love the Terra Dome from RDNA but you can get BagginsBill's Environment dome for free, you just have to hunt down testures for that on your own - they're there on the internet, but the Terra Dome comes with textures AND lights...)
Youngdeathknight ( ) posted Tue, 03 September 2013 at 12:14 AM · edited Tue, 03 September 2013 at 12:21 AM
Poser 9
thanks.
ashley9803 ( ) posted Tue, 03 September 2013 at 1:29 AM
For top-notch metal shaders go here-
Snarly's Space for EZMetals, an essential for all Poser users.
Youngdeathknight ( ) posted Tue, 03 September 2013 at 1:36 AM
thanks
aRtBee ( ) posted Tue, 03 September 2013 at 10:42 AM
note that's not only the texture which make a sword look real, it's the pose of the figure using it which contributes also.
Just do a simple lenght x width x depth estimate for it, and 10grams per cubic centimeter. Usually, a mens-high sword of some serious width and thickness has half the weight of the warrior him/herself, and just swaying around with it makes it look like a plastic toy even if the materials are good.
have fun
WandW ( ) posted Tue, 03 September 2013 at 12:49 PM
Swords aren't necessarily trerribly heavy; the Wallace Sword ia a two-handed claymore that is 5' 6" including the hilt, and weighs 6 pounds...
freyfaxi62 ( ) posted Tue, 03 September 2013 at 4:36 PM
How to make swords look "Real" ?? All very good advice regarding shader's and lighting..but the best way to make swords look "Real" ?? Go do some basic research on REAL LIFE swords, and have your characters use those. Forget so-called "Fantasy" style blades that no-one in RL could ever wield...all spikes and wierd shapes. And forget the "Over The Shoulder" sword scabbard so beloved of fantasy arists - if someone is simply carrying a sword, slung over the back , merely to move it from one place to another, maybe across the back is OK. But you can't DRAW a sword in a hurry from that position- the human arms simply can't do it. As said before real swords..one's designed to be used in battle, aren't all that heavy..say 1 and a half to just over 2 pounds for a single handed sword.
Youngdeathknight ( ) posted Wed, 04 September 2013 at 10:06 AM
Thanks for the suggestions.
svdl ( ) posted Wed, 11 September 2013 at 3:10 PM
The 15th century Scots often wore their claymores on their backs. But drawing the blade consisted of dropping the scabbard/baldric combination while holding the hilt.
My gallery   My freestuff
svdl ( ) posted Wed, 11 September 2013 at 3:13 PM · edited Wed, 11 September 2013 at 3:13 PM
Another thing, a well balanced 4-5 pound sword is fairly easy to wield. I did that in real life with a 5 pound hand-and-a-half.
The trick is, you grasp a large sword with a long hilt close to the crossguards, not in the middle of the hilt. That would be murder on your wrist. Quite a few fantasy images depict the wielder holding the blade close to the center or the end of the hilt - that doesn't work!
Winterclaw ( ) posted Wed, 11 September 2013 at 9:55 PM · edited Wed, 11 September 2013 at 9:56 PM
Quote - Swords aren't necessarily trerribly heavy; the Wallace Sword ia a two-handed claymore that is 5' 6" including the hilt, and weighs 6 pounds...
But the men at arms buster sword weighed around 50lbs and threw the guys back out when he tried to use it.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
