Forum Moderators: wheatpenny, RedPhantom Forum Coordinators: Anim8dtoon
Freestuff F.A.Q (Last Updated: 2025 Feb 17 4:09 am)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered. Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
Attached Link: http://www.sparkyworld.co.uk/3d10own.htm
![file_498552.jpg](https://live.cdn.renderosity.com/forum/threads/2873148/file_498552.jpg)
Recently while helping a colleague to buy a TV, got to see one of those new fangled and incredibly expensive 4K tvs. Running a really impressive incredibly sharp timelapse .MP4 demo. Almost beyond hyper realistic. Being heavily into digital imaging couldn't resist a closer look :) and it reminded me of both parralax scrolling and also layers. To which the nice shop confirmed, in basic terms 4K TV is literally 4 very flat very sharp TV's layered into one. Which got me thinking :) What if that was replicated within poser? Take 4 very thin "layers", literally as thin as possible aka one sided polys with no thickness, so any any shadowing would be reduced. Next stack them very close together. Then use transmaps on 4 images with varying degrees of blur. Then it's all combined into one single prop. Which as you can see from the contents of the zip actually works reasonably well. Obviously these where just quick test ones, and I'm sure you can do much better. Indeed if you used photographic techniques such as HDR and image stacking your results would be amazing. But this zip contains more than just a rendering aid, inspired by GenDragons excellent dioramas it also contains a small sci-fi room set where a set of 4K plates are actually built into the mesh. Though if you don't fancy going res the set will work just like any other prop, just set the "window plates" to totally transparent and remove the texture map and transmap. It's not very sci-fi either as this was made mostly to show the concept does genuinely work. A tip on the simple 4K plates only model, the orgin - the big green cross - has been set to "on". This isn't a mistake it's so you can see easier. It will vanish during rendering, but f you wish to turn that off just select the properties of the plates model and untick "show origin". Finally please remember the plates aspect of this model is more about proof of concept. So if you if wish to improve on this and share your results and setting you're encouraged to do so. http://www.sparkyworld.co.uk/3d10own.htmPinky - you left the lens cap of your mind on again.
