Thu, Dec 26, 11:51 AM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Dec 19 7:58 pm)
Subject: DSON PP2014 iMac problem
3Dpixi ( ) posted Mon, 30 September 2013 at 1:20 PM · edited Thu, 26 December 2024 at 11:37 AM
I have an huge issue adding DAZ related firgures to my scene using DSON. Hardware iMac software PoserPro 2014.
The little pic. is 1 pop-up that multiplies numerous times resulting to the larger pic.
Realy hope someone can help me clear this up ..
'cause I am not able to work like this and I need it to create products for my store.
Thanx already ..
Peggy
P.3D.Art
3Dpixi ( ) posted Mon, 30 September 2013 at 1:21 PM
this is the multiple result :(
Razor42 ( ) posted Mon, 30 September 2013 at 9:21 PM
I have seen similar to this using poser 9 and Dson on my imac. I found that generally leaving it to do its thing, the dson script eventually resolves the issue /completes the process on its own. For some reason it takes quite a looonnnggg time to load anything with dson but seems to be quicker the second time its loaded. Have you tried just leaving till it finishes?
Also make sure your running the latest versions of the Dson script and poser.
When its completed all of the dialogue boxes will close on there own. Eventually...
3Dpixi ( ) posted Tue, 01 October 2013 at 12:39 AM
Yup : I have the latest versions of all needed for sure ... All in the right folder.
I have let it finish .. indeed takes a loooong time and a looooong day with this happening by all I add through DSON. And when I'm finaly done and save a scene with these stuff in it Poser shuts down after re-opening that scene .. so I can start all over again >_<
But soooo glad finaly someone recocnizing this ..
And realy hope there will someone responds with the answer and true to fix this!!
Razor42 ( ) posted Tue, 01 October 2013 at 1:18 AM · edited Tue, 01 October 2013 at 1:22 AM
Is this happening on all DSON content or only on certain items? Such as clothing, props, or other items you've created Poser companion file for?
I have just done a few tests in Poser 9 and I noticed it seems to happen with specific clothing items I had created a while ago, but not with others. So I suspect it was something I was doing wrong in the Poser companion files I had created at the time. To be honest most things seem to be loading a lot quicker now then I remember.
We need to work out if its the DSON Script itself or the specific items companion files causing the slowdown.
One suggestion which you may already know is to Set Subdivision to off.
Under scripts/DSON Support/ SubDivision - Off
This may speed things up slightly but I suspect its not the core of the issue your having.
3Dpixi ( ) posted Tue, 01 October 2013 at 3:32 AM
I haven't create any Poser companion files myself ...
But indeed you nailed it :
No problems at all with adding DAZ originals ..
Only with the Poser companion filed items indeed
As well in PP 2012 as in PP 2014 .. it's the same.
I didn't know about the SubDivision - off so I wil take a look at that.
I would appreciate big time if the scripting will be checked :
maybe the companion files, the py files or DSON script that don't match eachother perfectly.
  • I'm not that technicus -
Realy hope to keep posted on that..
.. and sorry if my English isn't that great :D
Razor42 ( ) posted Tue, 01 October 2013 at 4:35 AM
So just to confirm,
When you load a Daz Original using DSON it loads fine(No Slow Down)?
(For example: Daz DSON Clothing onto a Genesis figure in Poser.)
The problem is when your trying to load a 3rd party clothing item onto Genesis in Poser using DSON? (That comes supplied with its own Poser Companion files?)
Sorry a few things in your last post left me a little confused.
Just trying to offer what help I can. Even though I found for the most part DSON causes more problems then it solves.
3Dpixi ( ) posted Tue, 01 October 2013 at 2:06 PM
Yes .. this issue happens with products Poser Companion files only
bhoins ( ) posted Sun, 27 October 2013 at 7:23 AM
Fixed in the latest release of DSON Importer for Poser.
3Dpixi ( ) posted Tue, 29 October 2013 at 3:40 AM
yay! .. gonna get right away!
Thank you .. can't wait to try :D
3Dpixi ( ) posted Mon, 11 November 2013 at 7:45 AM
could you please point me to the updated DSON that should have solved this? 'cause the one in my productlist still causes this in my Poser .. :(
It's when adding a new figure to the scene and when re-opening a saved scene.
bhoins ( ) posted Mon, 11 November 2013 at 4:48 PM
I know it got fixed before 1.1.1.17 got released. (From the scripts menu, choose DSON Preferences and check the version number.)
3Dpixi ( ) posted Tue, 12 November 2013 at 2:33 PM
Ok .. I will take a look at it .. thanx :)
