Mon, Feb 3, 10:42 PM CST
Subject: Characters Merging
Grum ( ) posted Tue, 08 October 2013 at 2:59 PM · edited Mon, 03 February 2025 at 7:57 PM
Hi All.
   Hope you can help. Getting back into Poser are quite some time, and got myself 2014, and now use Win7 64bit. Loaded a lot of stuff from my archive and got stuck in. I created a couple of characters, one on the M4 base, and one on the K4 base. Each was given a name and saved to their respective external runtimes. I also saved them to my library, again into their appropriate runtime window. Fine so far. Each will individually load into a new screen with no problem, however, if I load K4 into a screen in which the M4 character is already loaded, the K4 character does not appear, but the pose and morphs move to the M4 character. If I do it the other way round, K4 first, I get an equal and opposite effect. I'm sure I'm doing something dumb, because I've never had a problem like this, way back when.
Hope someone can suggest something. Cheers Gray
markschum ( ) posted Tue, 08 October 2013 at 5:54 PM · edited Tue, 08 October 2013 at 5:57 PM
what are you clicking to load the figure. In Poser 7 there are two check buttons. One loads a new figure, one replaces the current figure with the new one.
It sounds like you are doing the replace option.
I dont know how the 2014 library works but it should be fairly obvious and there is always the manual.
just reread your post and you dont describe exactly a replacement so make sure you are loading them correctly to eliminate that. Perhaps try one of the native poser figures to see what happens there.
hborre ( ) posted Tue, 08 October 2013 at 6:26 PM
In 2014, you can set the mouse behavior of loading figures/props into the scene through the General Preferences.  The double-click options are *Add to scene *or Replace existing.  I don't remember which is the default. You also get replace or add new options with the check buttons at the bottom of the Library as markschum stated.
Grum ( ) posted Wed, 09 October 2013 at 1:51 AM
Yea, a bit vague there, wasn't I. I'll go back and try a basic model and then load a saved character. I'll be back.
Cheers. Gray
