Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 01 3:49 pm)
No solution just questions incase they help provoke ideas (no need to provide answers if you feel of no use)
When does the short cut stop working, when Daz studio is started or when you exit from it
Do you have seperate runtimes for Daz and Poser content?
What is the Poser shortcut actually pointing to?
Have you checked the drive Poser is installed on for errors recently?
Could this be caused by AV detecting a problem with the Poser exe (have you checked AV log).
Many thanks for all your replies. In answer to some of your questions.
The Poser Pro 2014 .exe file disappears completley from the Poser folder.However the runtime stays.
The shortcut stops working when after I close DAZ Studio down and try to open Poser.
I have separate runtimes for both Poser and DAZ.
The Poser shortcut is pointing to the .exe program in C: Program files/SmithMicro/PoserPro2014. Runtime is on same drive.
Daz Studio Advanced Pro was on a separate removeable 1 terrabyte hardrive.However the Content Manager at the time was on my C:Drive.
I have checked that that there isn't any errors on the Poser Drive.
I do use AVG free antivirus and a paid version of AVG PC Tune up.However I have been running this system for years without trouble.
Windows installed about 27 updates recently.I doubt if this would be the problem.
Finally I have uninstalled all DAZ Programs,Content Manager and Install Manager.
I have reinstalled DAZ Studio Pro,And I still get the same result.
DAZ have replied and pointed me to their help desk.But this is all about installing DAZ products.
I am at lost to know what is happening! Cheers
Custom built computer 128 gigs RAM,2 Terrabyte hard drive, NVIDIA RTX 3060 12 Gig, Intel i9, Dual Dell Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terrabyte SSD Hard Drive plus 1 Terrabyte Hard Drive,3rd Computer intel i7,64 gigs ram, Graphics Card NVIDIA GeForce GeForce 1660 Ti 6 Gig,1 Terrabyte Hard Drive, OS Windows 10 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus Lenovo Laptop 64 Bit,12 gigs Ram.Intel i7 chip.Windows 10 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.22, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
For the moment I seem to have fixed the problem. I re installed Poser Pro into C:/Program files/Smith Micro folder not C:/Program Files Smith Micro Poser Pro 2014.
I then made a copy of the .exe and put it in a folder marked Poser Pro 2014. This contains the main runtime.
I have since open and closed both DAZ Studio Pro Advanced 4.6 and Poser Pro 2014 several times and all seems to be working properly. I really do not know what has happened. Maybe something got moved accidently.However I think it was a Poser problem not DAZ!
Many thanks for all your advice and help! Cheers
Attached Link: Process monitor
As the title to this thread says, this is very weird. If the problem returns and you are curious to find out if the file is being deleted by Daz Studio (seems unlikley) then the sysinternals Process monitor will show detailed file operations for a process. It's not the easiest tool and consumes a lot of your time but is useful in these cases.This seems too specific to be a disk corruption problem but might be a good idea to catch up on any backups you do just incase.
