Mon, Nov 25, 12:29 PM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 24 6:27 pm)
Subject: Seeking some help with creating a skin
wolfyfeetz1 ( ) posted Sat, 19 October 2013 at 4:41 AM · edited Thu, 01 August 2024 at 7:30 PM
 I have a couple old skins for the V3 model is there a way to snatch an image of the Mat? I would like to use these again but first I would like to alter them to suit a a new purpose. Is there a way to get a jpeg copy of the surface of V3?
Medzinatar ( ) posted Sat, 19 October 2013 at 9:37 AM
More than likely it is already a jpeg (could be png or bump)
Just open it with your 2D editor of choice and do desired alteration.
DazShawnDonaldson79 ( ) posted Sat, 19 October 2013 at 10:07 AM
Specifically there is a file already on your computer with the texture. In Daz Studio it's referred to as the Diffuse Map, other programs call it a Texture Map.
On Windows it's under your Runtime/Textures folder, but there's usually a lot of stuff in there.  Also, most models have several textures for one body, ie. one file for the face, one for the torso, on for the arms/legs.
  If you know who made the texture you can sometimes search your Runtime folder and find it, otherwise try this:
Load Vicky3 and apply the texture.
Select Vicky 3 and open the Surfaces Tab of Daz Studio (Main Menu ->Window -> Panes (Tabs) -> Surfaces).
Make sure the Editor tab is selected near the top of the pane (not the Presets or Shader Baker).  There will be a listing of the various body parts.  Click on the Torso (or closest equivalent, maybe SkinBody or something).
The file you're looking for is under Diffuse Color.  There will be a color selector and a small box with a down arrow.  Click on it and select Browse from the top of the list.  This will open a dialog box letting you select another texture map.  While you don't actually want to change anything, this will let you know exactly where the files are located.  I usually go up one folder level in the open dialog and then right click and click Open In New Window, to get a new browser window.
For further reading see:
http://docs.daz3d.com/doku.php/artzone/pub/software/dazstudio/reference/tab_surfaces
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/surfaces/videos/surfaces/start
I hope this has been more helpful than confusing.  All info is based on Daz 4.6 and Windows.  Your milage may vary.
