I am not familiar with the MAC environment but I assume the procedures are relatively the same under a Windows OS. When installing V4, there is an primary initialization to prep the model for morph channels. Then install the Morph++ pack and rerun the initialization again to prep the model to receive the pack. Load a new V4 into the scene and inject the morphs++. Everytime a new morph pack is introduced, the initialization must be rerun. To check if the initialization had taken, load a base V4 into the scene and look at the Parameters tab for a new channel entitled Morph++. Everything should work after injecting the pack. Do not attempt to add morphs to a V4 model already saved into your Library or .pz2 scene prior to installing the Morph++ pack, those models would not have the appropriate channels established to accept the pack.
I have downloaded Victoria 4.2 and Victoria++ morphs but I can't seem to get the morphs to load correctly. After I click to load the dials appear but there is no response. Like the pregnant morph will load into the parameters tab but when I move the dial nothing happens. The shoulders move a little but that's it. I even go to my V4 folder and run the initalization but when I go back and load V4 none of her morphs work. It's like her body is still locked or something. Everything I do doesn't seem to work. If anyone can help I would apprecieate it. Thanks.
