Tue, Jan 21, 2:12 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 21 5:37 am)
Subject: how to let genesis skin bump
atpo ( ) posted Mon, 02 December 2013 at 7:22 PM · edited Thu, 12 December 2024 at 4:14 PM
try many times ,but after render no bump.
does the bump image uncorrect,how to adjust the bump max or min?
and the dispalcement.
Razor42 ( ) posted Mon, 02 December 2013 at 7:40 PM · edited Mon, 02 December 2013 at 7:42 PM
You can acess the bump and min max settings in the *surfaces tab.*
Select Genesis then change to your surface tab then you can edit the settings. The default skin tend to use lower quality images so you may need to invest in a high quality character pack with materials like Mike 5.
See image above.
atpo ( ) posted Wed, 04 December 2013 at 12:10 AM
usually,I scale the bump to 40,min and max bump no scale.
Is this the problem?
Razor42 ( ) posted Wed, 04 December 2013 at 12:14 AM
Maybe, the Min should have a negative numer to indicate the negative bounds of the bump.
Try changing it to:
Bump Strength: %100
Bump Minimum: -1
Bump Maximum: 1
Maybe that will help with the issue :)
atpo ( ) posted Wed, 04 December 2013 at 12:26 AM
thanks ,
But sometimes I scale bump to 150,and also no bump after render
Razor42 ( ) posted Wed, 04 December 2013 at 12:30 AM
Are you applying material presets to your figures?
When you apply a material preset all of these should be set automatically.
Are you trying to set skins up manually?
atpo ( ) posted Wed, 04 December 2013 at 12:51 AM
yes i do it before ,the resault is figure to the that material figure.
and now I do not.
manually yes.
Seeyou later
