Sun, Jan 5, 4:46 AM CST
Subject: Problem with JCM in clothing for BVH Cynthia
MarianneR ( ) posted Thu, 05 December 2013 at 1:27 PM · edited Sun, 05 January 2025 at 4:25 AM
I'm trying to add a JCM to a top for BVH Cynthia. I've made a morph to smooth the area under the arm when Cynthia's shoulder body part is moved up and down. I can't make it work though. If I let a morph drive the JCM instead it works. I also tried with V4 and Stephanie 3 and then the morph moves as it should (although of course the clothing doesn't fit). The code below is from the BODY part of the clothing.
This one doesn't work on Cynthia, but it does work on V4 and S3:
valueParm LShldrUpAdj
name LShldrUpAdj
initValue 0
hidden 0
enabled 1
forceLimits 0
min -100000
max 100000
trackingScale 0.004
keys
static 0
k 0 0
interpStyleLocked 0
valueOpDeltaAdd
Figure 1
lShldr:1
zrot
deltaAddDelta 0.018
This one works on Cynthia:
name LShldrUpAdj
initValue 0
hidden 0
enabled 1
forceLimits 0
min -100000
max 100000
trackingScale 0.004
keys
static 0
k 0 0
interpStyleLocked 0
valueOpDeltaAdd
Figure 1
chest:1
BreastsCleavage
deltaAddDelta 0.018
Any ideas? Looking in the cr2 I've noticed that there are a lot of lines containing the word bone, like "twistX bone_8_twistx". Could that be the problem or should I look elsewhere?
WandW ( ) posted Thu, 05 December 2013 at 2:43 PM · edited Thu, 05 December 2013 at 2:44 PM
Looking at the Cynthia cr2, I think it should be :
name LShldrUpAdj
initValue 0
hidden 0
enabled 1
forceLimits 0
min -100000
max 100000
trackingScale 0.004
keys
static 0
k 0 0
interpStyleLocked 0
valueOpDeltaAdd
Figure 1
lShldr:1
zRotate
deltaAddDelta 0.018
MarianneR ( ) posted Thu, 05 December 2013 at 2:50 PM
Thank you, thank you, thank you!!
That did the trick!
WandW ( ) posted Thu, 05 December 2013 at 2:58 PM
YAY!! :biggrin:
