Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Hey, you! Hope all else is well.
If you've tried updating your display drivers and deleting your prefs (not necessarily in that order), then I would suggest contacting Smith Micro Technical Support.
(this assumes you have the latest version of your copy of Poser installed).
I don't think I've clicked on the Content Tab on purpose since Poser 7.
What version of Poser? There are updates for 9 and 10...
"Oh - the manual says that? I have never read the manual - this must be why."Interesting. Are you using the Internal or external library? I know some folks were having it crash on startup using the internal librasry, but it worked with the external Library. If you are using the External Library, don't try Internal, as you then will likely have to edit Poser.ini to use Poser again
Either way, I'd file a support ticket, if you haven't already...
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Just lately when I click on the content tab I get a Poser exe. problem and it shuts down.
The Program works fine in all other areas, just the content tab. Is there a way to fix
this without reinstalling?
Thanks for any help.
Duncan
