Mon, Dec 23, 5:21 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
Subject: Poser exe.
bebopdlx ( ) posted Mon, 16 December 2013 at 1:44 PM · edited Tue, 03 December 2024 at 10:26 PM
Hello all.
 Just lately when I click on the content tab I get a Poser exe. problem and it shuts down.
The Program works fine in all other areas, just the content tab. Is there a way to fix
this without reinstalling?
Thanks for any help.
Duncan
FightingWolf ( ) posted Mon, 16 December 2013 at 3:14 PM
Just out of curiousity.  What happens when you right click on the Poser Icon and run it as administrator? Do you get the same error?
bebopdlx ( ) posted Mon, 16 December 2013 at 3:46 PM
Thank you for that info. I did try it and got a new message.
ironsoul ( ) posted Mon, 16 December 2013 at 3:51 PM · edited Mon, 16 December 2013 at 3:52 PM
A not responding message in content screen is a sympton of the IE11 upgrade conflict with Poser.
If you think this applies and have pp2014 there is an update available (SR3), not sure what's happening with a fix for pp2012 (last update I saw was WIP as of 6 Dec)
Teyon ( ) posted Mon, 16 December 2013 at 3:53 PM · edited Mon, 16 December 2013 at 3:54 PM
Hey, you! Hope all else is well.
If you've tried updating your display drivers and deleting your prefs (not necessarily in that order), then I would suggest contacting Smith Micro Technical Support.
(this assumes you have the latest version of your copy of Poser installed).
bebopdlx ( ) posted Mon, 16 December 2013 at 3:56 PM
Wow, it did start with IE11.
WandW ( ) posted Mon, 16 December 2013 at 4:11 PM · edited Mon, 16 December 2013 at 4:12 PM
I don't think I've clicked on the Content Tab on purpose since Poser 7. 😉
What version of Poser?  There are updates for 9 and 10...
http://poser.smithmicro.com/updates.html
bebopdlx ( ) posted Mon, 16 December 2013 at 4:25 PM
I am using Poser Pro 2012. The tab is how  I install from zip files.
WandW ( ) posted Mon, 16 December 2013 at 4:34 PM
Interesting.  Are you using the Internal or external library?  I know some folks were having it crash on startup using the internal librasry, but it worked with the external Library.  If you are using the External Library, don't try Internal, as you then will likely have to edit Poser.ini to use Poser again
Either way, I'd file a support ticket, if you haven't already...
bebopdlx ( ) posted Mon, 16 December 2013 at 4:54 PM
I uninstalled ie11 and it work perfect now.
