Thu, Dec 12, 12:31 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 11 2:52 am)
Subject: trying to make a poser didgeridoo
estherau ( ) posted Wed, 01 January 2014 at 6:54 PM · edited Wed, 11 December 2024 at 9:47 PM
I used a staff from a staff set at daz which used DSON to put it into poser.  to my suprise the grouping tool worked and i was able to cut off the bit I wanted and discard the rest of it.
I need to make it wider at the bottom than the top I think.  But there is no taper dial.  I then decided to try the morphing brush to make it look a bit more didgeridoo like. However the morphing brush only seemed to work on the rings at the top and the bottom of the object.
So then I exported the .obj and reimported this, thinking it would now work, but I still can't use the morping brush except on the very top or the very bottom of the cylinder.
Any ideas how i can make this thing into a didgeridoo?
MY ONLINE COMIC IS NOW LIVE
ockham ( ) posted Wed, 01 January 2014 at 7:02 PM
Poser is always ready to taper a prop.  Most props don't have taper dials, but you can add them.
You probably want a taper on Y here.  Just insert this paragraph among the others like XoffsetA and Ytran and so on.  If the prop happens to be built oddly so that the vertical isn't really its Y dimension, try changing the word taperY (in three places) to taperX or taperZ.
                taperY taperY
                        name taperY
                        initValue 0
                        hidden 0
                        forceLimits 0
                        min -100000
                        max 100000
                        trackingScale 0.04
                        keys
                                static  0
                                k  0  0
                        interpStyleLocked 0
My python page
My ShareCG freebies
estherau ( ) posted Wed, 01 January 2014 at 10:05 PM
the vertical definitely is Y so I will do as you suggest.  Thankyouso much!!!
estherau ( ) posted Thu, 02 January 2014 at 12:27 AM · edited Thu, 02 January 2014 at 12:31 AM
didn't really work.  the dials appeared and did things but not really well tapered. I think because it is a DSON imported object originally. because teh morphing brush only works on the ends. that is very weird in itself.
estherau ( ) posted Thu, 02 January 2014 at 12:28 AM
oh I just discovered something. tamperingn with the originY dial after using the taper dial actually works!
vilters ( ) posted Thu, 02 January 2014 at 3:04 AM
Use a magnet to open up the end.
estherau ( ) posted Thu, 02 January 2014 at 3:47 AM · edited Thu, 02 January 2014 at 3:56 AM
thanks but i have tapered it adequately now I think.
wonder why the morphing brush refused to work on it.
NanetteTredoux ( ) posted Thu, 02 January 2014 at 5:26 AM
The morphing brush was probably hampered due to the vertex distribution in the object.
Poser 11 Pro, Windows 10
estherau ( ) posted Thu, 02 January 2014 at 5:42 AM
Must be a Daz Studio thing. Honestly I was surprised, but happy, that the grouping tool worked.
RobynsVeil ( ) posted Sat, 11 January 2014 at 3:37 AM
Agreeing with Nanette on the morphing brush: with extremely - or sometimes, even moderately - low-res mesh, the morphing tool spits the dummy. I've had to export dynamic clothing mesh and add geometry in order to fix folds and stuff with the morph brush after a sim that didn't go altogether as planned.
Metaphor of Chooks
estherau ( ) posted Sat, 11 January 2014 at 7:51 AM
well anyway i made my little pic.
thanks everyone for the help.
Love esther
