Tue, Oct 22, 6:27 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 3:39 am)
Subject: Poser 8 and Windows 7 Pro
goido ( ) posted Fri, 24 January 2014 at 8:37 PM · edited Tue, 22 October 2024 at 6:24 AM
Is Poser 8 compatible with Windows 7 Pro 64 bit?  Thanks.
willyb53 ( ) posted Fri, 24 January 2014 at 9:08 PM
It should if you have the latest SR.  Note that some have had problems if IE11 has been installed.
Latest SR at http://poser.smithmicro.com/poser8updates.html
Bill
Schurby ( ) posted Sat, 25 January 2014 at 8:05 AM
I use 8 on Windows 7 Pro, but be sure to use Explorer 10. Or you will have problems with your Library showing.
Schurby
goido ( ) posted Sat, 25 January 2014 at 10:48 AM
Thank you guys, I just got my new computer and I was planning on putting my library on my E: drive because my C: drive is a SSD and it is super fast but does not have lots of room. I will check which Explorer it has eventhough I use mostly Chrome. Hopefully with the library in a different drive it will not be a conflict if I have Explorer 11 pre installed.
hornet3d ( ) posted Sun, 26 January 2014 at 4:42 AM
Quote - Thank you guys, I just got my new computer and I was planning on putting my library on my E: drive because my C: drive is a SSD and it is super fast but does not have lots of room. I will check which Explorer it has eventhough I use mostly Chrome. Hopefully with the library in a different drive it will not be a conflict if I have Explorer 11 pre installed.
I have the same setup and it seems to work fine.  The E drive is accelerated by using another SSD fitted to the motherboard but the speed gain is minimal.  I also have taken an image of the C drive in case the SSD fails and back up the E drive on a regular basis.  In theory this should allow me to apply the image to a new SSD and continue or, in the case of an E drive failure, load the backup to a new conventional drive.
goido ( ) posted Sun, 26 January 2014 at 10:36 PM
Quote - > Quote - Thank you guys, I just got my new computer and I was planning on putting my library on my E: drive because my C: drive is a SSD and it is super fast but does not have lots of room. I will check which Explorer it has eventhough I use mostly Chrome. Hopefully with the library in a different drive it will not be a conflict if I have Explorer 11 pre installed.
 I like that, I even have Colud based back ups because installing from scratch or losing files is a pain!!
